Curly Maple Update
Curly Maple Update
Curly Maple Update
David Yoho
>To add to my earlier posts about the stash of tiger maple I got, I wanted to share something else. I got to worrying about whether my jointer and, to a lesser extent, planer would handle this figured maple without tearing it up and causing the need for another tool purchase that I don't really have the space or money for right now.
I'm happy to report I put that worry to rest yesterday. I cut about a 2-ft. piece off one of the pieces of 4/4 rough stock. I began by running it across my 8-inch Delta jointer to flatten one face. My jointer knives are not newly sharpened but I figured if there was a problem, I'd switch them out with a spare set I have sharpened and ready to go. To my surprise, since this is where I thought there would be issues, the cuts were perfect!
Next, I jointed one edge. This is where the cuts weren't as perfect but still acceptable. I cut off some waste on the other side at the saw and returned to the jointer to remove the saw marks.
With one face flat, I ran the board through my Delta 13-inch two-speed planer and took it down to exactly 3/4-inch thick. As I suspected, the planer did a stellar job with no tear-out.
I didn't sand the surfaces but did apply some clear Danish oil to highlight the figure so it would show up better. I must say it's absolutely awesome looking and depending on which way the light hits it and your viewing angle, the figure just seems to move!!
I had all these visions of drum sanders and Shelix cutter heads dancing around in my thoughts before this. Boy am I glad they're gone!!
David
Re: Curly Maple Update
T.T.I.W.W.P!
Gary Evans Tallassee, TN
>Where's the pics?
Gary
what a shame
Mike Schwing from Md.
>You missed a perfect opportunity to upgrade to the Shelix cutterhead. Be assured, not all tiger maple and figured woods will find you so lucky as you were this time, but I'm glad it worked out so well for you.
I absolutely cannot believe the performance of the Shelix head in my jointer. It cuts mirror smooth surfaces in the gnarliest of woods, even does a perfect, really perfect job on end grain! I recently glued up a tiger maple table top and squared up the thing on the bandsaw and then ran the end grain along the jointer with results beyond belief. It looks like a razor blade sliced it.
I find myself looking in the savings for a planer upgrade now as I have to decide which side will be the show face at time of thicknessing. Often I go back to the jointer after planing for a final pass. Would be wonderful to have both devices with shelix heads.
I shoulda known...
David Yoho
>I thought I could get away without a picture... oh, foolish me! Okay, here's a close-up I snapped in a hurry. Still no substitute for seeing it live though.
David
Re: what a shame
David Yoho
>Yeah, Mike, I hear you. Until I can scrape together the cash for such a luxory, I'll have to work with what I have and keep my scrapers handy. Sure would be a nice addition!
David
Re: I shoulda known...
>Thank you.
Gary
David, that stuff is
Stuart Hough
>BEEUTYFULLL! Can you put me in your will, 'cause I know you'll still have some of this stuff left!
Greg Haugen
>Man!! Just apply some finish and hang it as is!! :-) That's some gorgeous wood!! Please show us what you make with it.
Have fun,
Greg H.
Re: I have a Shelix and can help you David
Brian in Brighton
>All you need to do it send me that beautiful wood and I can happily surface one side of it for you.
I MUST warn that on a few rare cases the Shelix worked so well that it cut all the figure right out of the wood. I put in some birds eye and got back 1/4 sawn. Strangest thing. You might end up getting just simple straight grain maple back. But I'll happily try to see what I can do to help myself.....errr.....you out. :-)
Can't wait to see the finished product.
Brian in Brighton
David Yoho
>I had no idea those Shelix heads worked like that! Brian, you're just plain bad ;-)
Thanks,
David
Re: David, that stuff is
David Yoho
>Thank you, Stuart. I don't expect to have any of this current stash left when I'm done. I will most likely be going back for more next year (which ain't far away) if my plan works!
David
You betcha
David Yoho
>Greg, you can bet I'll be posting pictures when I'm done. Who knows, I might even send it in to Shop Shots.
I'm planning on at least one blanket chest from this stash. I have several other projects in mind for it too but need to see what's left first. There's always more where this came from though.
Thanks,
David
wet the wood
Mark Valsi
>Dave,
I use a wet rag to coat the surface before I run anythning with a "figure" thru my planer. it helps !!!
An old standby
David Yoho
>Yes, Mark, I have used that one before too. I will keep it in mind as I get around to planing more of this stuff.
Thanks,
David
