Way OT: A/V gizmo needed (wanted?)
Jason Roehl in Lafayette, IN
>Without going into the particulars of my home theater setup, a new component will be added next week some time, and for optimal performance, I'd like to be able to strip the digital audio off the HDMI cable that will run between this component and the TV and convert it to a digital coaxial or even a digital optical/TOSlink. Is there such an animal? I've poked around a few sites, but haven't found anything. If such a device exists, what is it called? I'm also hoping this device would not be more than $10 or $20.
Basically, this device outputs digital 5.1, but the TV only passes 2.1 back out, thus the desire for a stripper/splitter (I wish I had known that BEFORE I bought this particular TV, but I don't mind the work-around challenge too much).
Jason
Re: Way OT: A/V gizmo needed (wanted?)
Not cheap. HDMI-> DVI + TOSLink?
Jeff Gerardot, Indianapolis IN
>I only found a $299 gizmo for you, and I'm not sure it'll work (does your TV take DVI?)
I'm amazed at how fast HDMI is obsoleting receivers & equipment. (yeah, I know I just verbed "obsolete")
Maybe someone with more expertise will have some better ideas.
Nope...
>...the TV has 2 HDMI inputs. One is already taken, but the gizmo of my dreams needs to be HDMI in > HDMI + (coax/TOSlink) out. Even with the digital audio out, I'll have to put in a switch of some sort because my receiver is old enough that it has only 2 digital inputs (one each of coax and optical), and they're both taken.
Jason
Okay.......
>Okay.... you KNOW that if you're not going to tell us now, you HAVE to tell us what you got yourself for Christmas. Sounds interesting espceically if all those input are already taken. Must be some system :)
Happy Woodworking!
It's not for me...
>"It's for the kids." Yeah, that's my story and I'm sticking to it.
The system isn't anything too special--40" Sammy LCD, quasi-digital Yamaha receiver (5.1 hooked up, 6.1 capable), dual-tuner Motorola DVR (80GB, from the cable co.), Sony DVD-recorder, an old Panasonic VCR, and an XBOX.
So you can maybe guess what's getting upgraded...
Jason
Forget about it
Mike Schwing from Md.
>It is not worth the hassle. Even if you find something, it'll be a hodgepodge that will likely only work with whatever current HDMI standard your equipment uses. Is it 1.1 or 1.3? Plus, one of the questionable features of HDMI is digital content protection. HDMI devices talk back and forth in ways conventional components do not, denying attempts to break up the signal, specifically to protect what you are trying to do - break it down into components. Ooh - great segway - many HDMI capable blu ray and HD DVD players won't output high resolution over component cables for just that reason - they can't protect the content from copying over component.
I can't see anyone making such a thing as it would violate the HDMI agreements - everyone that includes HDMI into their components agrees to use it according to specific rules - what you're looking for violates those rules. It would certainly cost more than you suggested as HDMI licensing costs more than that.
Time to upgrade that receiver.
You _should_ be taking your HDMI cable into a receiver and running the audio and video out from there, but you already know that.
BTW, save yourself a LOT of money and buy your HDMI cables from monoprice.com
Re: Forget about it
Bill White
>What the h$%l are you talking about? I got lost until you started in about "CHEAP".
Bill
X-BOX 360 ????
Nintendo wii ????
Re: Forget about it
>I already knew about monoprice.com, so the HDMI cable is on the way as we speak.
I had forgotten about the digital content protection stuff--bummer.
I guess I'll just have to make do with the current setup or figure something else out. The receiver isn't all that old (5ish years?), but an upgrade will have to wait at least a few months or more, due to the new component.
I'd like to smack some people around for continuing to curse us with the rat's nest of cables--HDMI could be such a cool setup if every device had one in and one out so that all the components could be daisy-chained together and would grab whatever signal off that cable they needed. But that makes too much sense [/rant]
Jason
Re: Forget about it
Glenn Madsen near San Francisco
>Well, daisy chaining components really only makes sense if you want to use ALL of them in the stack. Most of the time, I want only one or two, and would much rather run only the ones I want to at any given time.
Of course, we have no gamers here any longer. They can run their own systems now...
Re: Forget about it
>I suppose that an HDMI daisy-chain could contain a powered-off by-pass for just such an occasion. Whatever. I just want to see the rat's nest gone, as I'm sure millions of others do as well. From power cords to RCA cables to coax and HDMI, then there's speaker wire and even a Cat5e cable. Heck, even a single DC source (with multiple, controllable outputs) would be nice for all those items with the bulky, transformer plugs.
Jason
