DJ-20 woes
DJ-20 woes
DJ-20 woes
Paul Cates - Henderson, KY
>Hi everyone,
I was going to post this under weekend accomplishments (inventing new swear words while adjusting my DJ 20 jointer), but I decided to seek the wisdom of this board.
I bought a Delta DJ-20 jointer new in 1999, and always enjoyed using it. I merely had one quibble: the darn thing seemed to go out of adjustment easily and I never figured out why�until now. I haven�t used the jointer much at all for several years but I intended to start a big project this week and the blades needed changing. Got the blades installed and proceeded to check the tables for coplanarity. They needed adjusting so I loosened the set screws and grabbed my curved-jaw Channel Locks. (Delta makes a spanner wrench to adjust the eccentric bushings, but why didn�t Delta include it with the jointer? That always irked me because it�s a PITA to adjust the bushings with pliers, plus it chews up the bushings.) After adjusting the tables (via turning the bushings) and tightening the set screws, I was raising the infeed table when I noticed that the bushing was turning. Arghh! Didn�t I tighten the set screw? Yes, but found out that there are TWO set screws in each hole (call me ignorant), one on top of the other, so I was always tightening the top one and the one that is supposed to press against the bushing�wasn�t. I investigated further by removing all the set screws and bushings and found that two bushings were scored, but get this: 6 (out of 8) holes were not drilled all the way through making it impossible to tighten the bottom set screw so that it would keep the bushing from turning.
Haven�t I read about others having problems with their DJ20 not staying in adjustment? If so, the stopped holes may be the problem. I spent all weekend adjusting, dismantling and cussing that thing while thinking about dumping it for another jointer (I wish I had the room and cash for an Oliver!), but my senses prevailed to solve and fix the problem.
The set screws have M6 threads, but in order to drill and tap the hole all the way through, I�ll need to up the diameter a bit and re-tap it. If I drill the hole with a 6mm bit, that will eliminate all the threads, correct? Then I can tap it with a 7mm tap. Does that sound like a good plan?
Do I have any recourse with Delta? Would you all fix it yourselves or call Delta? I don't want a new jointer, just a tech to come over TOMORROW and fix it! LOL
I like the DJ-20 just fine (except for the problem described) and I�ll probably fix it myself (and at my expense), but what upsets me is that it wasn�t made right in the first place. :(
Thanks for reading and for any advice/thoughts,
Paul
Re: DJ-20 woes
I'd call Delta
>I've been aware of the two-set-screw situation with these jointers for a long time, but having never owned a DJ-X jointer, I never had to worry about it.
Since you don't know what the manufacturing specs are on those set screw holes, I wouldn't risk having to remanufacture the whole arrangement from scratch, unless you're confident enough of your engineering assessment. It would probably be cheaper and better to have Delta supply you with some replacement parts, if that'll work, or to give you the benefit of any other advice they might have. They're good people and try to help, so I'd exhaust that avenue first.
Re: DJ-20 woes
Re: DJ-20 woes
Virgil Johnson
>Ouch... the old jam set screw trick. That has fooled a few people. Bummer about the holes not drilled through.
Why do you have to re-tap the holes? I don't think you will find a 7mm set screw. I would look at tapping holes out to 1/4-20 IF they must be re tapped. Tap drill for M6 is .196 (english) and for 1/4-20 is .201 Close enough for this job.
My DJ 20 has stayed put but this is good to know.
Virgil
Re: DJ-20 woes
Re: I'd call Delta
George@Colonel's Workshop-Havertown, PA
>Good Evening Paul,
It wouldn't surprise me if Delta shipped you a fully tapped replacement at no cost. They are certainly aware of the defect.
George
Re: DJ-20 woes
You couldn't give me a Delta for free..
Bri in Mtl
>Every single Delta product I've owned, large and small, I've had problems with. All are thankfully gone except for the bandsaw which is OK now after having it's initial problems taken care of.
Maybe I was unlucky but when it's as many as 5.....
Re: DJ-20 woes
Re: You couldn't give me a Delta for free..
Jim Shaver Oakville, Ontario
>I've had a few Delta's Bri, I used them awhile then sold them all eventually...:-)
Take care,
Jim
Re: DJ-20 woes
I May Be All Wet, But
George (Oxford, NC)
>couldn't you just drill through with a 5mm bit and run a 6mm tap down? The threads already there will guide the tap so that the new threads will line up. You may not have the full 70-75% threads in the newly tapped portion but the upper (old) threads will hold the screw (the new threads simply being a guide so to speak).
George
Re: DJ-20 woes
I'll take a Delta for free
>I'll take about anything Delta made. As long as it was built in the US.
Anything built after (not sure of the year, late 90's early 2000? ) that was made in China/Taiwan.... well that's a different story :(
My US made Delta machinery has been superb, my DJ20 which was built half and half, was good, my other stuff made in Taiwan has been fair.
Actually my Delta 1"x42"-8" sanders are quite nice. I wanted to buy one for a long time when they were US made at $299, and then the started making them in China and the price came down to $100. I picked up two at $50/each at Lowes liquidation, and while sometimes I imagine the older US made ones might have been better built, these two have been very good at 1/6 the price.
But there's no doubt in my mind that the China/Taiwan made Delta equipment made in the last 10 years isn't as nice as my earlier Detla equipment. If I were buying today, I'm not sure I'd choose Delta. It's really to bad to have to say that.
Happy Woodworking!
Re: DJ-20 woes
I'm thinking.....
>I'm thinking that if he tried tightening and tightening the outer set screw, and it just jammed up against the inner set screw, then he probably fears (as I would) that he's stripped or weaken the threads and wants to re-bore and re-tap to make sure it's good and strong.
Happy Woodworking!
Re: DJ-20 woes
Sorry... supposed to be a reposne to George
Re: DJ-20 woes
Re: DJ-20 woes
Sean Troy
>Paul, sense you just live down the road, you can just drop it off at my shop and be done with it. Really though, if you need any help with it, call me. San
Re: DJ-20 woes
My thinking about drilling and tapping the holes
>For those of you not familiar with the DJ-20, the holes I'm talking about are in the cast iron base that the tables sit in, so the only way to fix it (that I can see) is to finish drilling and tapping the holes or for Delta to provide me with a new base. It must weigh at least 150 pounds, and it's all cast iron.
I saw a tap drill size chart that said I needed a 5mm drill bit for 6mm tap. But a 5mm bit is larger than the existing hole and would ruin the existing threads if I wanted to drill the rest of the way, so I thought that if I made the hole larger to remove any existing threads and re-tap for a larger set-screw or bolt, then I'd have good threads all the way through.
I happen to have a 6mm tap and according to Virgil, I need a .196 bit and not 5mm. I also happen to have a .196 bit (must have used it with the 6mm tap at one time? duh!), and it will just barely go down in the hole. So if I end up going that route, it seems that will work.
This board is the best! Thanks for all the responses...I'll call Delta tomorrow and see what they say.
Re: DJ-20 woes
Re: DJ-20 woes
>Sean,
Thanks for the offer. I've been meaning to contact you...if you have any free time during the next few weeks and want to talk shop, just call or email.
Paul
Re: DJ-20 woes
Here is a thought.
Virgil Johnson
>First open the holes with a 3/16 bit. (.1875) ( After the clueless tech rep tells you that you don't have a problem or the machine is out of warranty, or yes we will send you a casting in 16 weeks) Take one of the set screws and grind the threads off to a distance greater than the distance you just drilled. The turned down section of the screw will pass through the 3/16 dia hole. Or drill the hole out to the dia of a piece of steel you have on hand ( #16 nail for example) and drop this in the hole ahead of the set screw. this will pass through the hole and act as a spacer between the set screw and collar.
Re: DJ-20 woes
clever
Mike Schwing from Md.
>I believe this is the solution I'd try if I were in your shoes. Clever, elegant, simple.
Re: DJ-20 woes
Side benefit to that
Denis Ch�nard, Orl�ans, Ont.
>Now you can say you're environmentally conscious, since your machines are all green :-)
DC
Re: DJ-20 woes
Another ? for DJ-20 owners - 1 setscrew or Shapie?
>After I went through the frustration of finding that my DJ-20 has the double set-screw feature, I seriously considered removing the two and just using one. I never got around to it.
I'm curious to what other's have done.
Has anyone removed the two set-screws and replaced it with one?
Or have you simply used the Sharpie solution ...... use a black Sharpie marker to write "TWO SET SCREWS" next to the holes in the cast iron to remind yourself.
Happy Woodworking!
Re: DJ-20 woes
Re: Another ? for DJ-20 owners - 1 setscrew or Sha
Virgil Johnson
>Simply making it a habit of ALWAYS checking for jam set screws will save you loads of frustration.
Re: DJ-20 woes
Re: I'll take a Delta for free
Alan in Little Washington (NC)
>Not all the older Delta machinery was made in the US. A lot of the heavy stuff was actually made, or parts manufactured, by Invicta in Brazil, but it was still great stuff. I have a 1986 commercial duty Delta RC-51 20" planer. It says "Delta" on the front, but "Invicta/Delta" on the ID plate on the back.
This summer I aligned my DJ-20 after installing a Shelix. Now I need to go and see if it has two sets of sets screws.
Re: DJ-20 woes
Re: DJ-20 woes
Brad Chenoweth
>Paul,
Simply pick a drill that just fits in the tapped portion of the hole, and drill the hole through with that, then tap the hole all the way through. The drilled hole will already be the minor diameter of the existing thread (same percentage of thread). That's what we'd do in the machine shop where I work. Take care.
Brad Chenoweth, in Elyria, Ohio
