Electrical?????
Ron
>When you hook up a generator to a junction box do you turn the main breaker off or leave it on some people say turn it off others say it doesnt make any difference thanks
Electrical?????
Ron
Re: Electrical?????
Gene Gauss
>YOU MUST TURN THE MAIN DISCONNECT BREAKER OFF!!! Sorry to shout, but it is most important to isolate the circuit you are powering with your generator from the power lines that normally provide power by opening the Main Breaker. The best consequence of not not opening the Main Breaker is probably overloading your generator because of the loads connected to the line waiting for power to be restored. The worst consequence of not opening the main breaker is energizing the power lines and possibly killing a utility worker who is working on the line when your power is applied. I don't know who's telling you it's not necessary, but don't buy any bridges or used cars from him. Gene Gauss
Re: Whoa . . . Depends
>on whether you're out to kill the lineman who's trying to restore power to your home and neighborhood!
If you do not throw your main disconnect to isolate your house from the power grid before applying generated power to your home, that same juice will travel back up the line, through the transformer that steps down the voltage to your house (so it's now stepped UP) with enough to electricute the guy who "thinks" he's working on a dead line.
In my not so humble opinion, someone who does what others have told you, that "it doesn't make any difference," should be prosecuted for criminal negligence, if not forced to support that lineman's family for life.
Set your system up right or don't do it at all. The life you save may be your own.
mm
Re: Electrical?????
Earl
>Check with your power company they may have something to say regarding your hookup. My understanding is that if your power goes back thru the transformer it will be transformed to the HIGH VOLTAGE. For my generator I have disconnect switch. Earl who is not a lectrcion
Re: Electrical?????
JohnKJordan in East TN
>You can purchase isolation devices to connect your generator to the house wiring. However, you would have to have a huge wompin' generator to run the entire house.
When I lived where the power was inconsistent, I ran separate and isolated circuits from the generator to a central location in the house. I did not connect it in any way to the house wiring. When the power went out, I used heavy duty extension cords from those outlets to the fridge, lights, etc. Besides the low cost, this simplified things a GREAT deal with only the minor inconvenience of running the cords.
Re: Electrical?????
Bill Howatt
>I don't know what the code says but you may find that you need a transfer switch which makes it impossible to back-feed the power line from the pole. Anything that relies on somebody remembering to flip a switch or breaker is an accident in waiting!
Bill
Ron
>ya thank you this is not for me i am not an electrican a guy i work with was talking about this at work today i told him he better check with a LICENSE ELECTRICAN INSTEAD of these people with a name on the side of a pick up thank you very much and have a happy holiday
Transfer Switch Required
Jim Swank
>Bill is absolutely right! In every location I know of, a transfer switch is required so that your generator does not energize dead lines and possibly electrocute someone. Fancier methods are required if you're doing co-generation and selling electricity to the utility.
Re: Electrical?????
John Veerkamp
>You have had good advice. The simpllist way to do this is with a Generator pannel. The circuits you want to power in an outage situation are moved into this pannel. This pannel is powered by the main pannel when the stitch is in that position. When the switch is thrown then the pannel is powered from the generator and the connection to the main is broken. This way there is no possibility of back feeding the grid, or blowing your generator when power is restored.
Don't let your friend do something stupid.
John
Re: Had One
>like that up the street.
Now I have an 11,000 watt genset that I can pull out for emergencies. It feeds thru a transfer switch that breaks the service line before connecting to the generator. This is all wired in heavy cable. The deadbrain up the street thought that he was smarter than everybody else and hooked a 5,000 watt generator to his house by backfeeding one of the outlets in his garage. Fortunately his family all got out, but it's a vacant building lot now.
Yup, you guessed it, his insurance company refused to pay for the fire caused by a "blatant violation of the electrical code amounting to willful and wonton disregard of law."
mm
ps Didn't mean to snap at you, Don, but this kind of thing can't be emphasized too strongly.
I just helped my son
Rich Pearson in Mill Creek, WA
>install a generator panel yesterday. It DOES isolate the generator from the line input so running generated power back into the grid is impossible.
The directions with the panel were clear and the install was a snap. Generator power only goes to the circuits we selected, by individual switches on the panel.
I wouldn't do anything different, especially in the house my grandkids live in!!
Re: Electrical?????
>As a Home Inspector I see a lot of Generator hook ups.
They range from People who have a cord made up to plug the generator into the dryer outlet and back feeding the system to some sort of pigtail hanging out of the panel to a separated panel with an inter lock switch to a standby generator with its own fuel supply that starts itself during a power failure and has an automatic interlock.
All have some potential for danger, but most especially the ones that do not include the interlocks.
Think of the situation where you are most likely to need the generator. The power most often fails in fowl weather. Therefore, the scene will be that on some dark and miserable night you will be dragging the generator out of the garage, hooking up the cord, resetting your breakers to only leave on the circuits your generator can power, turning off the main, Starting the generator. All of this without your usual lights. You can't leave the generator in the garage or basement, the CO will kill you. (People die every year) If you leave the main on, you will endanger your neighbors (You could be sending power to their houses) and anyone trying to restore power. So, If you forget and start the generator for just a second to get the lights on so you can see and then flip the main breaker you could kill somebody.
Another thing that bothers me is that the generator hook up plugs that people wire to the panel have male prongs on them. So, if you leave the generator interlock in the "generator" position when the power comes back on, those prongs will be live. On "proper" ones they are recessed, but there is nothing keeping fingers out of there.
Before the big ice storm in 1999 we never saw generator hook ups, but after the storm we started to see home made scary stuff. More power failures and hurricanes went by and we See more and more elaborate setups including permanent automatic systems. Guess what I see now? Trucks riding around with signs on them advertising "generator repair and maintenance". If you have a power failure every five years, chances are that the generator you bought for last time won't run this time. The time to take care of it is not in the middle of the night in an ice storm. So you need to drag it out and run it a few times a year and have fuel on hand that has stabilizer in it. Maybe a lot of fuel. Fuel is dangerous.
Is this for real?- or are you just making a point?
Tim Greif - West of Chicago
>I've been asking about this for years. Everybody's got a favorite story where the insurance company refused to pay because of this or that sort of electrical violation. I have NEVER been able to find any documented evidence of that actually happening - anywhere. I've written it off as "Urban Folklore".
I've even had insurance people tell me that they simply don't deny coverage for stupid things people do, intentional or not.
If this actually happened, I'd like to see the details to document this.
Re: Electrical?????
Tony - Memphis
>Yeah, since we had Hurricane Elvis blow through, everybody and their brother bought a generator and decided it was easy to hook up to the house! Pretty scary. Several folks around here died via their generators. The storm didn't get but a couple, but the generators got several. We had one borrowed from a construction company that was pretty big. We kept it in a truck and drove it back and forth to my f-n-l's house just enough to keep the freezers in good shape. Between the noise and the fumes, the neighborhood was not a nice place to be (it was in summer). I've toyed with buying one, but its so rare that our power goes out (thank you to all the folks who provide that to us!) that I have a hard time justifying the expense and trouble.
Tony
I agree
Rick Christopherson
>I hate scare tactics like this. As one insurance agent put it, if we didn't pay out for stupidity, there would be no claims.
Two supplies juicing the same . . .
steve mackay
>set up ( any set-up ) at the same time ? Even the possibility ? SOMEONE at SOMETIME is going to get hurt. . . . BAD !
Re: Electrical?????
Rick Christopherson
>Article 700 and 702 of the NEC cover standby power systems. There are several code violations with what you are proposing, with the obvious being not having some type of transfer mechanism; and the less obvious is that you will have a ground loop with an effectively ungrounded generator.
I am concerned that if this is the primary question you are asking, that this proposed hookup has not be well researched or thought out. I don't normally tell people asking questions that they should not be doing electrical work, but in this case, you are not asking enough questions.
Re: Documents
>Sorry, no documents, only what the homeowner told me after the fact when he was shopping for a lawyer to sue his insurance company. Since I don't do that kind of law, I couldn't help him, but the structure was torn down and not rebuilt, so I can only assume that what the guy told me was the situation. He could, of course, have taken the insurance check, paid off his mortgage, and looked for some place else to live, but I wouldn't be privy to such details.
mm
Hardly
>a "Tactic", Rick. I have nobody to convince here nor a "dog in the fight" like a financial interest. But I've had enough experience with insurance agents and insurance companies over 40 years to know that while their "agents" get paid to sell policies and do "PR", the companies spend lots of money fighting claims. Did you know, for instance, that nothing that "agent" says to you is binding on the company? Whole lots of people come up short on coverage because they let the agent handle things, and don't read the policy (rather than the application form) when they actually get it. They often think, to their later chagrin, that their coverage is what the agent tells them it will be, and don't read the actual policy and its terms and conditions, only learning later that their actual loss is not covered as represented by the agent.
It may well be that the poor schmuck who lost his house and nearly killed his family was blowing smoke at me, but I've read bunches of court case decisions where insurers played very technical about the exclusionary language and coverage limitations in their policies. You know, that stuff towards the end of the 20-page policy document that nobody reads because their eyes have glazed over and some agent said "not to worry about it anyway, its all standard stuff," while selling the policy? I have personally caught glitches in insurance policies being sold to me that I struck out and insisted that the company (not the agent) countersign. Every one of them declined to do so after every one of the agents assured me there would be no problem. I shopped elsewhere.
