Dial Indicator question
Nathan
>I'm looking to buy a dial indicator and, as I expected to be, I'm a bit confused. Can anyone tell me what the difference is between a "25-0-25" face and a "0-25-0" face?
Also, is it normal for a dial indicator to not come with a contact point? Or do they usually come with one standard plus you can buy additional ones as accessories?
Lastly, does anyone know what a "lift lever" does for a dial indicator?
I do understand that I will need some kind of stand to hold the dial indicator while measuring.
Re: Dial Indicator question
Rick L
Rick L
>Easiest way is to read the specs in a catalog to learn. Also go to machinist sites and machinists books in the libary. Staying on the woodsites is very limiting. 0-100 is one rev is .010" 0-25-0 is half around is .025" and then the numbers decrese to zero at the top. Lever is to lift up plunger, not really necessary.
Best place to buy your indicator is www.use-enco or my favorite is www.wttool.com
Best prices and you only need to buy a $15 indicator. Most bases aren't really suitable for the woodworkers needs. Get the 0-100 and typically they come with a small point. Get the 1/2" b convex button tip and the 1/2" flat tip.
