Filling the pores of Walnut
Joe in a Cleveland suburb
>Hello.
I am (frantically) trying to complete a table for a Christmas gift. The top is walnut. I started to put finish on it (the top) last week. I started with several coats of thinned gloss oil based varnish followed by a couple coats of non-thinned. Looks pretty good so far. This walnut has some really nice figure.
Now, after it has cured a couple days I want to start to rub it out and put a little wax on it. The varnish/poly hasn't filled in all the pores.
I want to rub it out and level it to cut back the gloss a bit and have the nice feel of being waxed. Should I fill the pores somehow first? If so, how? How do you fill the pores? Would you bother?
If I don't fill the pores, does that create problems when rubbing out and/or applying wax?
Thanks!
Joe
Re: Filling the pores of Walnut
JohnKJordan in East TN
>I don't do much furniture, but I often use a commercial paste wood filler to fill the pores on walnut woodturnings before applying the finish. The can I have is labeled "Bartley, Dark". It results in a very smooth finish. I have no idea if it can be used after some finish has been applied.
Don't fill
>You'll just give yourself more heartburn. If you want an even sheen finish, rub back the current finish a bit with a maroon skotchbrite and recoat with a medium gloss varnish. Then rub it out with 0000 steel wool and Butcher's wax.
Clint
Steve Schoene
>After two thinned and two "full strength" coats of varnish on the top I believe it is too late to use a pore filler since the pores will have enough finish in them so that the filler won't be able to bond.
What you can do, especially since you haven't dyed or stained the walnut, is to sand more aggressively, being sure to use a sanding block, just to the point of cutting through the varnish to the wood on the surface. You will left with shiny spots where the sand paper can't reach the bottoms of the pores. Then apply another coat or two of finish and do it again. Eventually, you will reach the point where the pores themselves are being sanded essentially . This is a lot of work, but gives a very deep looking fully filled finish.
There is another "catch". With varnish the curing process continues for some weeks after it has dried enough to sand. This can lead to some shrinkage of the finish material in the pores, causing them to "reappear". That's why this process of filling with finish is often done with evaporative finishes such as shellac which are easier to sand and which don't have such a long curing process.
agree totally
Mike Schwing from Md.
>Not worth time unless you want a glass smooth finish.
