>As part of an experiment I need to drill holes in a plane blade (rated to be Rc55-60). Will a HSS bit (namely the LV ones) manage do drill through that steel? Or can I expect the drill bit to self-destruct? Do I need to spot-anneal the piece first?
No, a HSS bit will not do the job. A cobalt split point bit with medium pressure and lots of lubrication to dissipate heat probably would do the job if the holes aren't much more than 1/4". The other option - guaranteed to work - is to reduce the hardness of the blade just at the spot you want to drill by using a torch to anneal the blade. You can prevent the annealing process from spreading too far by draping a wet cloth to dissipate the heat. Just make sure to keep it wet! Assuming the hole is nowhere near the sharp edge, you needn't bother to re-harden.
>B&D sells bits for drilling glass that have worked for me. I use the drill press on it's highest speed and use water to lub and cool the bit. Build a clay dam around the area to hold the water. Bad Dog Tools sells similar bits they guarantee to drill hardened HSS>
>I was told you could drill a hole through a hacksaw blade with an ordinary bit if you would spot anneal it by putting a rod of the same size in the drill press and pressing it (spinning) against the spot for the hole until the spot glowed red and then letting it cool, That supposedly anneals the spot and you can drill it. I have not tried it. If it worked, it might be more "contained" than the torch.
I did see some drill bits at the last WoodWorks Show that would do it. (Bad Dog?) If all else fails you could contact the people with Wood Works and they could tell you who they were. They advertise on WC.
>Either point-anneal as discussed or go to one of the "grit-edge" bonded carbide partical drill bits sold for ceramic materials. A drill press with lubricant should be used with the workpiece securely clamped.
