Rockwell Band Saw - some questions
Basil Biberdorf
>I picked up a Rockwell 28-200 14" band saw on a homemade stand on Friday. (Paid $125, and the saw has a relatively new Dayton 3/4 hp motor on it. Seemed like an OK deal.)
I've been working over the saw. I started by replacing the cracked rubber tires with new urethane ones, and the old V-belt with a linked belt.
A couple of questions have come up, though.
First, what does one do for dust collection on this saw? There's no port for a dust collector or shop vac anywhere. Would I have to cut something into the bottom housing?
Second, what do I do about the slight table damage on either side of the blade slot? (See the photo in the next posting.) I wouldn't care, except that it's above the surface of the table by a hair, which could mar the wood surface as it slides over the table. Is filing the defect down the best option? Alternatives?
Re: Rockwell Band Saw - some questions
Photo of the nick in the table
Basil Biberdorf
Re: Photo of the nick in the table *LINK*
GerryinSurrey formerly Agassiz previously Halfmoon
>I made a dust collection thingie from a Lee Valley angled D/C fitting, some hardboard, a couple of dime sized magnets, and a bunch of epoxy. I cut the fitting so that it would fit around the blade and guides under the table. I glued the modified fitting to some hardboard, added a couple of magnets and voila! we have dust collection. The magnets make it easy to remove for blade changes. A couple of brushes mounted so that they sweep the debris from the tires would prolong the life of your tires. I would file down that lump on your table with a flat file and some elbow grease. Looks like you got a decent saw for a reasonable price. If you want help on setting up the saw Suffolk Machinery have a lot of usefull tips on bandsaw operation and offer top quality blades and bits and pieces for bandsaws.
http://www.suffolkmachine.com
George@Colonel's Workshop-Havertown, PA
>Good Afternoon Basil,
I would install a 4" DC port in the lower door of the saw. That would mean cutting a hole in the door. I did that on my present and previous 14" Jet band saws. Directly hooked up to my DC 4" piping, the arrangement effectively removes almost all the dust. Its well worth the trouble. I would take a file and remove the table problem quickly. Nice saw, by the way. Well worth the price, especially with the new motor.
George
George
I think that they call this sort of.....
Michael Stadulis, in Gloucester County, NJ
>.....post a stealth gloat!! Very nice saw at a very good price, Basil. Congratulations. -Mike
R. Lance in GR, Michigan
>congradulations on the saw...well worth the money you paid...definitely file the table flat...just take your time...as for the dust, you could try to fashion some sort of housing like stated above but I'd don't see any real need to go much beyond that...a bandsaw makes some sawdust and a few minutes with a shop vac will generally clean it up in short order both inside and out...your call...your saw.
>I agree with all of the above. I cut a hole in the door of my saw and did not like it because it had a tendency to push the door shut while I was trying to change the blade. I made a fitting out of a four inch "End Boot" from a duct supply house. It fits up under the side of the saw. Contact Iturra Designs and get their catalog. Order the brushes for the blades at about $5 and he will send the catalog along with it. The catalog has a huge amount of information and would be worth buying. Delta makes a fitting simialr to the one I made for their saws. I stole the idea from the Iturra Catalog. Did not want to pay $32 for somthing I coudl maek out of a $5 fitting.
Ray Binnicker
>Hey Basil,
I just recently fixed my Delta saw with a better dust collection port. I cut a 4" hole in the bottom door and installed a flanged fitting. I really like it as it has greatly increased the DC pickup.
Marv
>I don't know about you people who like to collect dust. Boy...some people will collect anything!....*smirk*
Marv
Basil Biberdorf
>Do you have a photo of your dust collection rig? I think I can picture what you describe, but as they say, a picture is worth a thousand words.
Re: I think that they call this sort of.....
Basil Biberdorf
>I hadn't intended it to be a gloat, but perhaps "stealth gloat" is a good term. I scrambled to get the deal before it disappeared. The guy, having advertised it $125, upped his asking price to $190, but still honored the $125 price to me. The saw included the miter gauge and fence also. I need to figure the fence out, though.
The deal would, in my mind, have been only so-so, were it not for that Dayton motor of such recent vintage.
Even so, there's some cleanup work to do. It runs well as-is, but would like to get it tip-top.
The whole deal was a blessing, for this cash poor pastor.
Basil Biberdorf------WebKitFormBoundaryRB32nxnLgJ2
>Thanks for all the helpful responses!
Bart Castleberry
>The lamp alone on it sells for close to $100 on the bay. You would have gotten a fair deal at close to $400. That saw is twice the machine todays delta saws are.
The Lamp
Basil Biberdorf
>What's so special about the lamp?
