Reading Your Boards-#1 checks
Bill Tindall, E.TN
>This is No. 1 in a new series. Looking at your lumber can tell you a lot about how it was produced, and how it is going to work. There will be no logical order to these short posts. When I get an informative picture I will post the message.
The picture shows a section of a cherry board with a serious crack running along one edge as well as a section from the adjoining end of this board. This board was FAS clear lumber when it came off the saw. The crack formed during drying. No amount of end coating or drying management would have prevented it. Why?
The piece cut from the end of the board tells the story. Note this board contained the center (pith) of the tree and that the cracks radiate from this center. For reasons that I don't know, the centers of trees typically crack while drying and nothing will prevent it. For this reason logs are turned during sawing to saw the boards from around the center. The center is isolated into a chunk(cant), often 3 x 5", that goes to the pallet factory to be converted into pallets, or 7 x 5" to be used for rail ties.
In cases the sawing strategy leaves the center of the tree in boards. The unfortunate person that buys this lumber (me for example) will see it crack during drying.
In my hands cherry centers are the worse for cracking, but it occurs in everything I have ever dried. I don't think it is predictable how far out from the center the lumber is likely to crack, but 1-2" is typical.
