The chemistry behind the stink
Bill Tindall, E.TN
>The handles are made from cellulose butyrate. This polymer is extraordinarily tough and clear which made it ideal for screw driver and chisel handles. It is also used in auto paint to align the metal flake to make the mirrored metallic auto finishes that are the rage.
Cellulose butyrate is made by chemically combining butyric acid and cellulose from trees to form the plastic ester, cellulose butyrate. Over time moisture can penetrate this plastic and undo the chemical combination (hydrolysis) to produce butyric acid, one of the odoriferous components of strong cheese and rancid butter. So, what you are smelling is butyric acid. If you nose works properly it can be detected at bogglingly low concentration.
The rate at which it forms is very slow so if the tools are stored in a ventilated location most people, especially cheese lovers, don't notice it.
My daughter works in the research labs at the company that makes this stuff. The odor of butyric acid penetrates clothing and leather. It is pretty easy to detect people at the mall that work making this plastic. Buy more chisels. She needs the work.
