Picture Worth 1000 Words
David Yoho
>Yesterday I wrote about my exploit to N. Va to buy a bunch of curly maple. Thought I'd post a shot of one of the pieces I brought back. Most of it pretty much looks like what you see here figure-wise. I haven't dressed any yet, so this is shot of the rough stock.
David
Re: Picture Worth 1000 Words
worth 1000 words or 1000 dollars??
Greg Haugen
>That is gorgeous! Nice find!!
Enjoy,
Greg
Lee Grindinger
Hey folks, take notice of the board edge
Lee Grindinger
>Many here pick through stacks of lumber. Curly figure is easy to see on the edge of the board in a pile of lumber. David's picture shows this. When you're looking for the special board notice the edges in a pile, it could tip you off to some wonderful lumber.
Lee
Re: worth 1000 words or 1000 dollars??
David Yoho
>Would it surprise you to know you're not that far off the mark for the amount I got? I didn't mind though because it was their premium stuff.
Thanks,
David
Re: Hey folks, take notice of the board edge
David Yoho
>Lee, right you are. I initially told Daniel I was used to selecting already surfaced lumber and was not sure I'd see the figure in rough stock enough to know what I was getting. As soon as he pulled the first piece of 4/4 and offered to go run it through their sander for a better look, I said it wouldn't be necessary because it was instantly obvious by looking at the edge just how much figure there was. I guess I was a little surprised to be able to see it so clearly in rough stock but the edges sure gave it away. In fact, I brought back several boards where the edges look almost like teeth on a saw.
David
Greg Haugen
>Oh I believe it! It's gorgeous!!
Greg
>A couple questions for you; is it hard or soft maple? And also I'm pretty sure you didn't mention the price in your original post. A nice find.
David Yoho
>It's soft maple - probably red maple but don't know that for sure.
Going on what I was told (so hopefully it's correct), the only figure found in hard maple is Birdseye. It's the soft maples that produce figure such as curly and quilted. There are many folks here more knowledgeable in these things so if this is incorrect, please chime in.
David
Hard vs soft maple
Ed Mulligan, Cape Cod
>Curly maple is more common in soft maple but it does occur in hard maple, albeit less frequently.
I pay from $4 to $12 a board foot for roughsawn 4/4 curly maple. I consider myself lucky if a board contains 50% decent figure so the 'real' cost is something like double the lumber yard charge.
Ed
>You will find curly figure in hard maple a lot less than you do in soft maple. I think it is a little harder to get a really nice finish on soft maple than it is on hard maple; the grain is a little more fuzzy. But I'm not a finishing expert. There are a large number of descriptions for curly maple, a lot of which is hype. I tend to think of two different groups of figure in maple; birdseye and curly. I don't believe I have ever seen birdseye in soft maple. The amount of figure will vary considerably and probably the hardest thing when working with solid figured lumber is getting matched pieces. Normally veneer is used for this reason. Of course I envy your stash, and am sure you will have a lot of fun with it.
