I did that!
Bill Hylton
>I built a pair of traditional raised-panel doors about 18 months ago, using routers to cut all the joinery. I used poplar�8/4 for the rails and stiles, 6/4 for the panels. The completed doors are 1 3/4" thick, though they're interior passage doors. I reported on the project in the Oct '06 Woodworker's Journal.
I cut some sample joints with bit sets from Freud and Infinity Tool before settling on loose tenon joinery instead of integral tenons. I used the entry/passage-door bit set sold by Infinity Tool to cut conventional cope-and-stick joinery. But 20 loose tenons really hold the doors together. I routed mortises in rail ends and stiles�3/4" wide and nearly 3" deep�with a DW625 plunge router (it has the biggest plunge range), a Microfence edge guide, a 4"-long upspiral bit, and a homemade mortising block.
I found some very informative articles on building entry/passage doors at WoodWeb.com. Do you know about staved construction? About using two panels back-to-back in an exterior door so the exterior panel can move separately from the interior panel? At the woodweb homepage, look in the Knowledge Base column under Architectural Millwork for Doors and Windows. Looks of good stuff there.
While surfing for ideas and information, I discovered the existence of a shop just a few miles from me that's been making custom doors for a decade. Check out historicdoors.com. Pretty impressive doors. I got a brief shop tour and a chance to talk to the 3 fellows working there. Saw a spectacular pair of 10-foot-tall, 2+" thick white oak entry doors with side lites and curved transom they were building for the U. of Penn.
Anyway, architectural doors are great projects. The doors I built were a whole lot easier to do than I expected. I just haven't gotten to the others I want to build for the house.
Good luck,
Bill
