Glass Etching advice needed.
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>Do any of you have experience etching glass? Or more precisely, I am wanting to do some work where I reproduce digital photos, and would like to achieve half tones.
I think I have seen some work which was well done, and maybe I should just outsource that part, but I would like to hear from someone who had done this, and maybe see some photos. I am just not sure what works well. Does anyone have experience with this?
Re: Glass Etching advice needed.
No Problem *LINK*
Garrett in Victoria
>The Woodsmith mag website has a video describing exactly how to do this, and it looks really easy. The only 'tools' required are a jar of etching paste from a hobby shop and a roll of plastic (electric) tape.
It's the third one down on the right side at the link below.
Cheers, Garrett
Woodsmith
Phil Joines Krum, Tx
>There at least three ways it can be done. Sand blast, one of the air brush companies has a small blaster that can do very fine details. Acid etch, available at a lot of hobby/art stores. You have to use a special plastic resist template with it. Engraving, either with an electric scribe, like a tool engraver, or a rotary wheel. If you have a Dremmel they have engraving wheels for it.
You can get the most detail engraving. All the methods can be combined on one piece. I like the air brush since you don't need detailed templates.
>If you want true half tone images, a photo resist mask has to be prepared on the glass and etched with acid. The process and chemicals to make the mask are from traditional photography darkroom procedures, but applied to glass.
Clint
Re: No Problem
>Thanks Garrett, I have done acid and sand blast before, but I need more detail than I can get by making my own mask.
Thanks Phil and Clint
>I have been searching through the net, and I'm finding a lot of sites which tell about it, and getting some good information. I was surprised to find that some of the resist can hold about 60 dpi for sandblasting images. I would not have thought the dots could hold on images that small, but then I am sure there are tricks, like smaller blast medium, and lower pressure.
One place required UV cure, another high temp, some need careful washing to get the mask medium off, yet one left it for the blasting medium. I need to see if I can find a sign shop with a large plotter to help me.
I did see a site where they were using dremel tips to add details. I have got a lot of those things already. I will get out in the shop today, and try some of them just to see how the details turn out.
Re: Thanks Phil and Clint
JohnKJordan in East TN
>Keith,
If you decide to go the sandblasting route, you can build a device that has some advantages over using a sandblasting gun. It uses a hopper - some times ago I made an illustration showing one I build many years ago - image attached. The nozzle is attached to an air supply through a manual valve - I used a petcock with a lever. The nozzle directs a blast of air straight up through grit in the hopper, directing it towards the hole in the foam rubber. The glass is pressed against the hole and etched a section at a time. One big advantage is the grit is contained within the hopper so you don't need to use a booth and none is wasted. I always used grit (silicon carbide?) purchased from an auto supply place intended for spark plug cleaning machines.
I used this to etch patterns onto round glassware. I'd cut masks from plain white paper attached to the glass with double-sided tape.
