Mirrors
woodenleg
>I have rebuilt the fallen mirror frame but I'm trying to figure out what to use to hold the mirror in the frame. The mirror is heavy and about18" x 30", it was held in by nails. Any ideas?
Thanks, Dave
Mirrors
woodenleg
Thanks, Dave
Re: Mirrors
George@Colonel's Workshop-Havertown, PA
>Good Afternoon Woodenleg,
I wish I could see a cross section of the frame involved. I've built a few frames for clients and my family. I've put double rabbets at the perimeter. One encloses the mirror sides, and the outer one accepts a plywood backer board retainer which I affix with small flat head wood screws. No glue.
Should this no fit your situation and you are unable to thicken the existing frame to accept rabbeted molding to hold a retainer board as described above, I'd try running a bead of silicone caulk around the interior frame where the mirror will bed.
George
I found the answer
woodenleg
>First, George thanks for the idea. The frame was built with no room in the rabbit after the mirror, papaer and thin piece of wood was placed. I used the little tabs that are used for holding screens in place on windows.
Thanks again, Dave
Re: Mirrors
Lee Schierer - McKean, PA
>I also like applying a plywood backer board (1/4" luan works great). It helps secure the assembly together when the frame is delicate and the mirror is heavy. French cleats are great for mounting the mirror on the wall so the mounting can't be seen.
Lee
