Spray Finishing
Paul T
>Hi All,
I'm looking to buy a spray gun for lacquer for a gift but don't have a clue as to what specs to look for. Any thoughts? What do you prefer?
TIA,
Paul
Spray Finishing
Paul T
>Hi All,
TIA,
Paul
Re: Spray Finishing
Greg Haugen
>Do you know if they use a "conventional" system or a HVLP (High Volume Low Pressure)system? That would help to narrow the options.
There are alot of good things to say about Gleempaint.com
Greg
Spray Finishing
Paul T
>Rookie Finisher with a conventional system.
Re: Spray Finishing
Bart Goldberg
>First question - do you have an air compressor, and if so, how big?
Re: Spray Finishing
Paul T
>Yes, 15 gallon porter cable, I don't remember the horsepower rating.
Re: Spray Finishing
Mac in Indy
>Get a hold of Jeff Jewitt at homesteadfinishing.com
He has a wide aray of products and can help you figure out what is best for you.
Mac
Re: Spray Finishing *LINK*
>Paul,
The suggestion to contact Jeff Jewitt is a good one. I'm linking this to Jeff's site where you can browse guns that cover a wide range of prices. You can also read and post on several of Jeff's finishing forums to get feedback from him and other finishers (pro's and am's) there, as well as call him directly (during the week) for recommendations and advice on equipment, methods, and materials.
What size compressor is needed?
Mark in Whitby
>I have a small pancake compr. and have heard varying accounts of its suitability for HVLP spray finishing. Other then the small tank and therefore the need to re fill more often are there any other impacts or obstacles?
thnx
Mark
Re: What size compressor is needed?
NickB
>Bigger is better, but it depends on the size of the gun. I've got a "3 HP", 12 gallon oilless that I use with a small HVLP gun (STM). The compressor runs a fair amount, but not all the time.
I second (or third) the suggestion to go to Jeff Jewitt's website. There is a general BB there where you can read up on previous suggestions, then post your exact situation to get a suggestion on a system.
OTOH, if you are spraying thin bodied clears like shellac and lacquer, I've heard good things about the Critter sprayer (but I don't know that it can atomize heavier finishes).
Hope this helps,
Nick
