>Has anyone had luck honing the teeth of a carbide circular saw blade? Mine's lost its crispness, and before I head off to the sharpener guy, I was wondering if using one of those diamond hand files I see in the woodworking catalogs would work. I've filed many steel blades in the past, but never attempted carbide teeth.
>I definitely wouldn't try it on a high-quality blade. Modern saw blades give smooth, ridge-free cuts without burning because of the close tolerances of their top and side grinds, especially the more sophisticated, smooth cutting blades that I suspect most of us use. When you're relying on .001" grinding tolerances to produce these smooth cuts, you can imagine how difficult it is going to be to maintain these kinds of tolerances with a file. If it's just a rip blade, and all you're doing is facing the teeth, it might not be too bad. I can't speak from experience on this though.
>I have never used one of those files on a saw blade but have tried it on router bits. I have never been satisfied with the results. As to the saw blades, I figure why risk ruining a $100+ sawblade to save a $20.00 sharpening fee.
