Can I use a Forrest WWII for MDF?
Mike Farinella
>Will I ruin (heat?) the blade? Is there a blade better?
Thanks
Re: Can I use a Forrest WWII for MDF?
Rob Stokes in North Vancouver
>It'll cut it like butta...
Rob
Rich Pearson in Mill Creek, WA
>I've never had a problem cutting anything with my Forrest blades.
Use it.
Virgil Johnson
>I've used mine for brass, alum, plywood, MDF, treated wood, plexiglass, lexan,Delrin, nylon, phenolic and various hard and soft woods. If you should not saw it I've done it. I've used the same blade for 14 yrs now.
Scott Whiting - Glendale, AZ
>You will not hurt the blade. Unless you are in production mode where you would want a TCG grind for a little longer life between sharpenings your WWII will be just fine.
Scott
Jesse Cloud
>MDF machines easily and well, just about any blade, including the one that came with your saw, will do just fine. It is hard on the blades, though, so you may need to resharpen the WWII sooner.
After you use the WWII on MDF, give it a good cleaning!
Gary Camp Bend, Oregon
>I hear they even cut block
glc
Mike - Careful...
David Yoho
>Just in case - Mike might not be aware of what this response is about. As they say, DON'T try this at home!
There's an old inside "joke" around here about a certain WoodCentral member who supposedly "tested" another member's WW-II on some block or stone.
Bottom line - as good as they are, they're not meant to cut rocks, stone, cinder blocks, or bricks... well, at least not more than once!
David
mostly a matter of speed...
John in New Mexico
>I'd say. That and various angles. A dry cut metal blade moving a few hundred rpm vs a few thousand should cut stone or block for a while. I have one of those old 9.6V Makita saws with a carbide blade, runs so slow it cuts old sanded plaster without significant dulling. Not about to try it with a Forrest though, diamond just works a lot better.
knotscott
>It'll cut great, but MDF is a known blade duller. If you're only cutting a bit, go for it. But if you've got a lot to cut, I'd choose a less expensive option.
Also, use DC and wear a respirator or a dust mask....nasty silty stuff that goes everywhere.
