Simpler LV Honing Rod Cases
Garrett in Victoria
>I mentioned last month that I liked these honing rods enough that I would be giving a set to each of my sons. Since I don't care for the clunky storage box design LV includes with its instructions, I came up with a couple of alternatives that might interest those of you selling at craft fairs.
I had a small piece of cherry that seemed like it would work, and after pondering what I could do within the limitations of its dimensions, I made two cases. I should have made a prototype out of a piece of 2x4, for I had to remake them with a couple of changes.
After cutting the piece in half I had two chunks 1 1/2" x 2 1/8 x 1 1/4. I drilled a 7/8" blind hole 10" deep on one side to store the 3 rods. I started with a brad point bit from an inexpensive Chinese set that nonetheless cuts a clean entry, and finished with a spade bit on an extension. I also drilled the three 3/8" angled holes without thinking things through.(See below). For these, I found that a Forstner bit left a cleaner entry than a brad point. All holes were drilled with the pieces clamped firmly in place.
I still hadn't figured out how to close the open end of the storage hole, so tried several ideas and settled on a simple plug. I first turned a slight taper out of cedar but that proved to be too soft. Spruce from a 2x4 was just right. It has enough give to lock without compressing permanently. The local specialty hardware store had the small pulls, and I countersunk their machine screw heads and backed them with a 3/8" washer. At that point I also saw that I had enough length on the cherry to cut the notch and was able to visually retract the pull 'into the box'.
I was happy with the result until I realized it had a fatal safety flaw. The black plastic rod is intended to protect the off hand against a blade that slips off the ceramic rod. It wouldn't do that in my in-line configuration. Rather, it has to be offset and brought forward from the ceramic rods. Back to the bench.
Another chunk of cherry produced blanks for 4 more cases, 2 of which I spoiled because I got over-confident and took a couple of short-cuts while drilling the deep holes. (Hand-holding while drilling with the extended spade bit is not good technique.) These blanks are 3/4� wider than the first set so that I could center the storage compartment. That made it possible to drill holes for the ceramic rods on one edge and the guard rod on the other. To protect the cork from being knocked out I cut the centred notch with a couple of passes over a dado set. It�s important to use something like a piece of 2x4 as a push/backer block. It�s safe, keeps the piece vertical, and prevents exit splintering.
I finished the first pair with oil but was not impressed with the result. The second pair has gloss wipe-on poly and I prefer it even though several more coats are required before they�ll be ready.(I�ll overcoat one of the first pair which I�ll keep for my own use.) As far as design is concerned, the first iteration is much more graceful and interesting to my eye, and would do well in a drawer. The second seems blocky. but because it�s balanced, could also be hung.
Cheers, Garrett
Re: Simpler LV Honing Rod Cases
Nice case ! . . .
steve mackay
>Soooooooooooooooo how you like'n them rods ? Sweet, yes ?
