Small DC motor question
jeff
>Hi all
I'm a bit rusty here on this topic.
I have a small DC motor on a drill.
But, it has no markings for the Volts or Amperage.
Can I safely hook up a Variable DC power supply to run it?
My supply can put out easily 30 amps at 3 to 15 Volts.
Is this ok or will it fry the motor.
Or, is there anyway to test the motor?
Jeff
Re: Small DC motor question
JohnKJordan in East TN
This is unclear: did the motor come out of an electric drill and you want to use it for something else, or did you get the motor somewhere and put it on a drill, or do you want to add a power supply to a drill that has none?
If it came out of a drill, can you determine what originally powered it?
>You should be able to test it out with your power supply. Start with the lowest voltage and see how it runs.
Under voltage should not hurt a DC motor (unlike an induction motor). Over voltage can. Start at the lowest voltage and start raising the voltage until it runs as you want.
It will run differently with and without load.
If you are worried about damage, can your poser supply limit current output? If so, limit the current to something moderate (not too low or it may not run properly). I can not tell you what moderate is for your motor, so you would need to use judgment and experiment.
If the motor is designed for a voltage over your maximum power supply voltage, it may just run slowly and weakly at 30V.
jeff
>Derek
I can limit the current on this unit.
I'll need to check as to if I have a higher voltage supply around here.
Jeff
jeff
>John
Sorry I wasn't clear.
This is a small precision drill press with an unmarked DC motor already on it.
The power supply and instructions are no-where to be found.
Jeff
Rick Christopherson
>If this is a cordless drill, then I would think it is pretty safe to assume it is in the 9 to 12 volt range, unless it is newer and then could be 18 volt. As Derek stated, you are OK with providing undervoltage to a DC motor, but providing over-voltage will cause too much current in the windings. Because you don't know what the current rating should be, I don't think limiting the current on your power supply will be of much value, because you have no idea at what amount it should be limited. As long as you keep the voltage down, the current should remain in a safe range unless you overload the motor.
Your best bet is to find out what voltage the original drill was using for a battery, and then keep your voltage below this value. Oh, if you know what batteries the original drill used, then you could figure out the maximum current the batteries could deliver, and then use this to determine the limit the power supply should be set to.
Nevermind
Rick Christopherson
>I see that you have updated this to say that the motor was from a drillpress, not a cordless drill. Given this, then the voltage could be just about anything.
I would check with the manufacturer (if possible) to see if they have a replacement motor. Not because you need a motor, but because they might be able to tell you what voltage the motor is.
If that is not an option, then you could try to find out how fast the motor was supposed to rotate at maximum speed. Duplicate that speed and you should be able to determine the maximum voltage using your variable voltage power supply.
Re: Nevermind
jeff
>Rich
Any suggestions on an easy way to figure out the rpm?
I don't have a tach available.
Jeff
Re: Nevermind
Rick Christopherson
>Well, there are several ideas. I have a voltmeter that records frequency, so I would probably come up with a more technical method. I assume you don't so I will give you a low-tech method.
Take a piece of thin string (or thread) of a specific length and count how many revolutions you can wrap it around the motor shaft. Using the number of revolutions and a stop watch, you can find the rpm. For your case, you would dial in the power supply until it took the thread a specific amount of time to spool onto the shaft.
Example:
Assume the string wraps 100 times around the shaft, and your target rpm is 500 rpm. This means it should take 1/5 of a minute to fully wrap the string, so you tune the power supply until it takes 12 seconds to wrap the string around the shaft.
Obviously this is super low-tech, but it would get you in the right ballpark for safely running the motor. This is the first idea that popped into my head, maybe someone else might have a simpler method.
