Book case
John Halstead
>Getting ready to order material for a bookshelf and I'm considering 3/4" MDF. I have not had a lot of experience with MDF therefore I would like any help you can offer
Book case
John Halstead
Couple things...
>It's heavy and flat, saws well (but very dusty -- use a respirator), routs well and glues well. It is used a lot for veneering substrate.
It doesn't like water, so plan on finishing it somehow. The edges absorb finish like you wouldn't believe, so you might want to size them with glue or something first.
It doesn't have the structural strength of wood or even plywood, so be observant of open span limitations in your shelf design. There is a "sagulator" website that lets you calculate maximum spans. Personally, I like to provide support along the length of the shelves, usually in the form of a stiff wood edging strip along the front, or "drop edge," as some people call it. This provides beam strength and protects the fragile edge of the MDF.
Hope this helps.
Ellis Walentine, Host
Re: Couple things...
>I agree with Ellis.
MDF is heavy and smooth and not very strong when it comes to spanning. I would use very short spans or some sort of hardwood edge stiffener. MDF shelves sag over time under their own weight and books are heavy.
When I was in college we built a bunch of (cheap/we were poor) "entertainment centers". They were MDF and any longish horizontal pieces had something like a strip of oak on the front edge that may have been two inches wide. Making the shelf look much thicker. The rest of the edges with covered with veneer tape in matching wood. The MDF we painted, often flat black. Sort of a nondescript cabinet with a decorative front. The ones that we thickened the edges on held up well. The ones without usually sagged.
