A55 Smoothing Plane
flooding basement?
flooding basement?
flooding basement?
ernie miller
>My sunp pump is not working along with the other problems.I have places sand bags from the sump pit to the floor drain. it is about a 1 inch rise the bags are tight to each other will it still fallow this rute to the floor drain? fingers crossed that this will work. if any one has a better idea let me know as my shop is buing threatoned. thanks Ernie shivering in ks
Re: flooding basement?
Grant in Iowa
>Cut a strip of plastic sheeting (or trash bags if you have none) about a foot wide and as long as your sandbag loop. Duct tape the ends together to make a big donut. Then duct tape an edge to the floor, then place the sandbags over the strip of tape and fold the excess plastic back over the sandbags. Instant waterproof levee.
You should know, however, that water is likely to seep up through cracks in the floor at the same time your sump pit is full. It'd be best to keep the water level below the bottom of the slab. If you can find a waterbed drain/fill kit, and you have water pressure, you could use the venturi and two hoses to drain the pit periodically. Let me know if you need a better explaination of this.
Regards,
Grant in Iowa
Ken Platt (Granby, CT)
>Ernie, I'm not sure I'm getting the picture correctly, but if you can push a hose down the drain so that it's end is lower than the top of the sump pit, you can siphon the water from the pit. Just fill a length of hose with water, stick one end in the top of the pit, and the other end anywhere lower that you can send the water to drain off.
Ken
(who is remembering vividly trying to empty a river from his basement with a shop-vac, one 15 gallon fill at a time.)
