heat? generators?
heat? generators?
heat? generators?
ernie miller
>Ok so we got hit hard last couple days I think I have a line on a generator 3000 MW will this be big enough to run the blower moter ans thurmostat on my furnace? also woul I be just as good to get a carosene heater or somthing else? no power for 10 days is the lattest word any ideas for warmth?
Re: heat? generators?
JohnKJordan in East TN
>I assume you mean 3000 watt generator, not 3000 MW (3,000,000,000 watts)? Or maybe you're going to power the whole city.
Before purchasing a generator add up the wattages on all of the devices you want to run at the same time. Equipment should have a plate with either watts or amps (w=v*a). Don't forget lightbulbs, fridge, freezer, etc.
Also, watch out for generator specs - some dishonest mfgrs will claim 3000 watts when the continuous wattage rating is less.
When I lived where power was iffy I kept the generator in a covered outdoor area and ran special outlets to the living area. (Never run a generator indoors.)
Kerosene heaters are convenient, can be used indoors, and are great for short term heating but very expensive to operate for extended periods. I like small, efficient woodburning stoves but they are not too portable and not quick to set up from scratch. We use a Vermont Castings stove and normally heat the entire house with it all winter.
Grant in Iowa
>Most modern furnaces are about a half horse motor for the blower, nominal for the electronics, and the thermostat transformer.
I think a 3KW generator would work fine.. Just know that a modern furnace has a printed circuit board in it and you *might* run a risk of damaging something by running it off of a generator. Should be OK, just be ready to fix it on the off chance that problems arise. Better than freezing, if you ask me.
Best type of generator is one rated to run electronics, such as computers, TV's, etc. for this purpose.
FWIW, (not an electrician, just live in the country and play one on weekends).
Grant in Iowa
ernie miller
>Thanks for the help looks like family is going to come thru with tempory sheltor and accept our pets also so we will be warm. we are working on a battery powered sump pump and will work on that later this evening
Jerry Nicholson
>3000 watts should do just fine. After the Great Ice Storm of 2005 in Wichita I managed to be at the Borg at just the right time to get a 5500 watt generator that I used to power the furnace, some of our lights, the television, the computers, a refrigerator, and a freezer (power was off for 6 days). Wichita declined major participation in the storm this week but the generator is sitting out in the shed waiting to be called into service. Y'all be careful with that generator - carbon monoxide and electricity can be dangerous stuff.
Jerry
