REAL MILK PAINT
Preparing curved substrate for veneer
Herb Yost
>I'm getting ready to apply 3/8" bending plywood to both sides of a torsion box arch (for a table). On top of that will go paper-backed veneer; the adhesive will be Better Bond Titan DX contact cement.
Neither surface of the ply is really smooth. There are minute cracks and voids. Sanding alone will not produce a smooth surface.
Given that I'm using paper-backed veneer, is it necessary to have a void-free surface? If yes, then what's the best thing to use to produce a smooth surface? Spackle, rock hard putty, two layers of contact cement, drywall compound...? This is the first time I've use such an "unsmooth" substrate, and wanted to get advice before going any further.
Re: Preparing curved substrate for veneer
Lee Grindinger
Yikes, yikes and double yikes!
Lee Grindinger
>Paper (membrane) backed veneers leave virtually nothing for sanding, they are often in the 1/100" thickness range. The membrane is what makes it possible to slice them that thin, natural wood falls apart.
If your substrate is not perfect it will telegraph through membrane backed veneer with no way to fix it.
I think you may need to rethink this part of your project. Perhaps a thicker veneer applied before your face veneer? You could sand the imperfections out of a thicker veneer and prepare your substrate to receive the very thin membrane backed veneer.
By the way, contact cement is the least reliable way to apply veneer, it's a "down and dirty" technique that has not survived the test of time. If your project is in the "down and dirty" category let 'er rip. If you're hoping to make something better rethink your design or execution.
If your heart is set on the paper backed veneer you'd better take great care in the preparation of the substrate.
Lee
Tom Norton-Chardon, Ohio
>Herb,
Just finished doing some veneering at about 6PM this evening and I might have a few suggestions for you.
As for your substrate skim coat it with Minwax 2 part wod filler and sand smoooth. As for adhesive I would suggest FSV, Flexible Sheet Vneer adhesive. Check out Joe Woodworker http://www.veneersupplies.com/
I have done complete kitchens and would strongly suggest staying clear of contact cement.
Tom
