Anyone own a Festool 5" ROS?
Virgil Johnson
>I'm interested in hearing comments on the ES 125 Q 5" ROS sander. I bought a new DeWalt which was very disapointing and is going back.
Re: Anyone own a Festool 5" ROS?
Bob Boswood
>I own a 6" and the large vacum and though the price was high, the equipment is very good. The vacum works great on my dewalt 621, almost no dust as opposed the clouds previously generated. The only problem with their sanders is that they only take festool sand paper.
Bob
I have the 6 inch and am very happy
Chad Pearson
>It is a fantastic machine with almost no dust when used with the vacuum. If I put the same vac on my 5 inch Dewalt I still end up with clouds of dust.
As to the comment above about only using Festool sandpaper I would mention that while the Festool machines are quite expensive I thought the sandpaper pricing was fair.
Re: I have the 6 inch and am very happy
WRF
>I have the six inch as well. Great tool to the point where I bought a few more festool items after this one.
I run it with paper other than festool and its fine. Also runs with the abralon discs and the micro mesh prodicts; also good dust collection btw thru the micromesh
I have both a 5 and a 6 inch Festool
Michael Dresdner
>I like them both, and they are both superior to any other electric sander I have come across, but of the two, I must admit that I reach for the six far more often.
Jim DeLaney, Austintown, Ohio
>I have both the ES 125 and the RO125 (Rotax), and I like them both. I haven't used either my Makita or my PC Ros's since I got the Festools. The ES125 is far smoother - less vibration - than any other ROS I've ever used.
Jim D.
Joe Burke
>Hey Virgil
Two or three years ago Festool ran some type of promotional special and I got a 6" sander for a lot less than it would have normaly cost. I'd buy one now at full price without hesitation. I haven't touched another sander since I got that one. If I buy another sander of any type I'll get one of theirs. I'd buy a lot of their stuff if it weren't so pricey.
I keep mine hooked to a PC vac with good results.
It runs very smoothly and I can't make it duplicate the problems I had with my PC ROS. Swirls and hard to handle. The power cord being detachable is a neat feature too.
I use Mirka paper. I bought no hole discs and a cheap set of punches from Grizzley and I use a Festool disc as a pattern and punch each disc. Takes all of 30 seconds. I need more discs and may try the 8 hole discs and just punch the center hole. I recently used some Abralon discs on some finish and that was a great experience too.
If anyone has a good source for discs I'd love to hear about it.
If you buy a Festool you won't regret it.
David Yoho
>Joe,
I believe you got your 150/3 about the same time I did. It is indeed a wonderful sander but, as Bob Marino told me, it is solely a finish sander due to its limited orbit. I like this one and use it all the time. However, your next Festool sander should probably be the 6" Rotex. It's great when you need to get down and really sand stuff but it's also good at getting the surface ready for the 150/3.
My other sanders don't see much action any more. With the addition of the Festool vacuum, I now sand without all the fine dust and almost enjoy sanding now!
David
Jesse Cloud
>I'll join the chorus. I have both the 6 inch rotex and the 6 inch 150/3. Since the area of the disc pi x radius squared, the multipliers for 5 inch is 25 and 6 inch is 36, almost half again as much for that one extra inch, so its faster, paper lasts longer, etc.
I usually use the Rotex for the first pass, to remove imperfections, then switch to the 150/3 to remove subsequent grit scratches. I like the rotex, but its aggressive and needs direction. The 150/3 is smoooth and as they say, 'almost fun to use.'
And my dewalt and pc sanders went on craigslist after sitting idle for 6 months. Never picked one up again after I got the festool.
Jay St. Peter - Southern, MD
>I have the ETS150/5 and like it similar to everyone else. It is more aggressive than the /3 version and I like that fact. I can still finish sand with it, just have to slow it down and be a little more careful. I have never heard much negative about the 150 sanders from someone who owns one. The 125 seem to get occasional negative comments about its lack of agressiveness. But, it is designed as a finish sander.
Jay
