THE WOODRAT IS BACK!
QS White Oak
QS White Oak
QS White Oak
Patrick Schupbach
>I salvaged a pallet today with beautiful 1x4 white oak runners. What is the best finish to get the rays to pop? Thanks!!
Re: QS White Oak
Re: QS White Oak
David Yoho
>A dye in a color you like should do the trick.
David
Re: QS White Oak
Re: QS White Oak
Ray Binnicker
>Patrick,
I have made some beautiful furniture from salvaged pallets. I'm getting to old, though, to deal with those &&*^&^* twist nails. I use a good penetrating oil 99% of the time followed by several coats of wipe on poly. The poly is optional, but the oil will certainly make the wood scream.
Ray Binnicker
Re: QS White Oak
Options galore
>Quartersawn oak offers lots of finishing opportunities. You can just oil or varnish or lacquer it, or you can opt for some other treatments. Dye stain will make it uniform in color. Pigment stain will fill the open pores and highlight the rays. Fuming will darken the rays and leave the wood open to whatever coloration you decide to do after that. Gustav Stickley's furniture was often fumed and then dyed with aniline dyes and finished with primitive lacquers, but I'm not sure he ever settled on a single finish he liked best, so there's a lot of variations around. Most of the Roycrofter-style pieces I've seen are pretty dark and contrasty for my taste, but that might be the look you're after.
One of the best pieces of the Roycrofter shops that I have seen is on display at the Grove Park Inn, in Asheville, NC. I just visited there again recently and snapped these pic of my favorite A&C clock. See if this is the sort of look you are after....
Ellis Walentine, Host
Re: QS White Oak
Any stain will do it
Michael Dresdner
>The ray cells resist both dye and pigment stains That means any stain you apply will increase the contrast between the rays and the rest of the wood. Pigment will also make the grain pores stand out, though dye won't. The only thing that does not add diferentiation is fuming, so avoid that. For that matter, any clear finish that has even a hint of color in it, such as oil based polyurethane or lacquer, will also help pop the ray cells. It's almost hard not to.
