couple of bed questions
lee beeden
>I'm building a double bed, the mattress is 54" wide. I have some left over pine strapping from building the shop and was thinking about using it for the slats( its been in the shop about a month.
can i span this distance with 3/4" x 3 1/2" pine slats? Or should I have a center support?
I should mention there is no box spring just the mattress, its 12" thick.
I thought about reinforcing the slats by running a piece of stock under the slats on edge to create a kind of I- beam what do you think of this idea?
Also where the rails meet the post the rail is about 11" wide. Now this a cross grain connection( grain on the post is running upwards ). There is no mortise in this design.If i connect with the traditional through bolt( i thought about using one and centering it about 5 1/2") is this a problem? How does the wood move?
I had initial thought about having 2 dowels, one at the bottom and one at the top to locate the rail and stopping it from twisting. And the one through bolt to hold it together. Does this work?
Any help with this would be greatly appreciated
Lee
Re: couple of bed questions
>Without a box spring I would want a better support than just the strapping. You could put a rib under them and that might do the job, but a center support would definitely do it. I recently made a bed for my son and made a little prop that just sat under the bed. It had legs on it and a top that had slots that matched the spacing of the slats. It just sat there, unattached.
I would definitely use dowels above and below the bolts to keep the rails from twisting if you don't use a mortise. I think I would put them about two inches down from the top and up from the bottom to reduce the distance in the cross grain part. I was slightly concerned on the bed I made about he weight of the bed hanging from the bolts only. So, I went ahead with a mortise to give it some bearing surface at the bottom. You could make your bottom dowel fairly large and in a snug hole. The top one could be in a vertical slot, with room for it to move up and down about an 1/8" just in case you don't trust that cross grain situation.
I used the bolts on mine with the bolts in the rails and the nut in the leg, so they would not show. I was very impressed with how solid the connection was. Remember, this connection needs to be stronger than you might think. There is the weight of the bed and bedding, the weight of the people, the fact that it has to last a long time, and there might be some dynamic stress on it as well. Better to over engineer.
Bruce, a MN galoot
>Lee,
I've made a half dozen queen-sized beds using the construction you're contemplating, only I used ash slats instead of pine. For one thing, ash is cheaper here than pine. It's also stiffer.
No need for a box spring at all, and these beds have held up with absolutely no problem.
Bruce
a clarification
Bruce, a MN galoot
>using the ash slats, I have not used a center support, nor has one been necessary.
Bruce
Angle iron and threaded inserts
Nathan
>Just a couple days ago I repaired an antique bed that some serious racking problems. It was constructed using a bolt/hook assembly in the center and dowels at the ends. The dowels had sustained damage and the holes they went into were in really bad shape. Instead of redrilling the holes and putting in new dowels, I used angle iron.
I went to the ironmongery (I don't know what they're called in the States - like a lumberyard except they sell all kinds of steel profiles instead of wood) and bought some lightweight perforated angle iron and had it bandsawn there to 4 pieces, each in the same length as the bed rail. I attached one angle iron to the end of each rail using three short, stout flathead woodscrews.
For reasons I don't quite understand, my wife likes to break this particular bed down periodically and move it from room to room. That's part of the reason why it had developed the racking problems. Still, the fix had to retain the ability to disassemble. I couldn't just use the same woodscrews to attach the the rails to the head and foot boards.
So I bought some threaded inserts and installed those in the posts. To put the bed together, just put bolts through the angle irons into the threaded inserts and tighten them up. The stability is amazing. That rickety old bed is now rock solid.
The angle iron I used is pre-perforated with elongated holes, so no drilling through steel and since the holes are elongated this has the added benefit of addressing wood movement. If the wood in the rail expands or contracts, the bolt will just shift slightly in the elongated hole. That's my hope anyway.
In my mind, this system has two advantages in addition to those listed above: 1. it's relatively simple (so much so that I could do it), and 2. no hardware shows from the outside.
If anyone wants pictures, let me know.
Slight hijack - what's the purpose of box spring?
John E
>I've been contemplating building a bed myself, and have thought about building it more elevated than "store bought" beds, and not using a box spring. Mattress alone would be cheaper, and you could have more storage underneath. Is a box spring nothing more than mattress support, or does it have some function? I would think wood slats would be plenty of support if engineered right, and would give some "spring" also. Just curious as to what other folks have done.
John
Re: Slight hijack - what's the purpose of box spri
Don in Northern Arizona
>John,
If you like a firm bed, you don't need a box spring. I built a queen-sized platform bed with drawers underneath that my wife and I slept on for 20 years or so. Supposedly box springs help the mattress last longer, but I think that may be 90% sales hype.
Don
>I had a mattress store owner tell me that the box springs were just another "sale" for him. That the mattress would actually last longer if it were places on a nice dry solid floor. I built a bed that had a sheet of plywood for the surface for the mattress. The problem was that it was slick and the mattress would slide around and the covers would not stay on it. Solved that problem by putting a piece of thin tightly woven carpet on the plywood. Nice and "grippy". No more slipping and the covers stayed in place.
