Speed calc. for lathe
Wayne
>Need some help on calculating speed on lathe. I have a motor that is 1750 rpm. It has a 4 step pulley, small pulley is 2" large is 5" lathe head has same pulley reversed. What is the speed of the lathe when belt is put on 2" at motor and 5" at head? What is the formula for figuring the speed.
Re: Speed calc. for lathe
wilbur
You take the speed of the motor, multiply by the diameter of the pulley on the motor, and divide by the diameter of the pulley on the lathe spindle.
For your setup:
1750 rpm * 2 / 5 = 700 rpm
Thanks
Wayne
A word of caution......
>The opposite is true also. If you described the pulleys correctly, and you put the belt on the other end of them, they will increase the speed by 5/2 X 1750 or 4125 RPM. That is very fast. Or it seems so to me, I turn mostly bowls. I don't think my lathe will go over 3500 and I almost never run it that fast. This would be a speed for tiny, well supported very stable spindles. Lots of bowls would fly apart at that speed. Be careful. You might consider a set of pulleys that would allow you to start at a considerably lower speed (200-300) and end up at about 3000, depending on what you want to turn.
Re: A word of caution......
Bob Entwisle in NJ
>5/2x1750 = 4375
Sorry, you get an A for showing the work, but an F for the answer....
OOPS, That's what I get for doing half
>of it in my head. Half of 1750 is 875 not 825.
OTOH, the concept still holds and what we don't know is what the "actual" diameter of either pulley is. that would be the diameter where the belt is running which is probably neither the outer rim nor the bottom of the groove.
The concern still holds. Don't think anyone familiar with wood turning will advocate that there is much difference between 4125 and 4375 from a safety stand point or that any of us should be turning anything at either of those speeds.
This means that the top speed on this set of pulleys is useless and worse, dangerous. He might get more enjoyment from the lathe if he changed the pulleys. Instead of have what is effectively a three speed lathe, he could have four more useful speeds.
(Does anybody turn at over 4000 RPM? I could be wrong. Maybe I am a big chicken.)
I'll take the A and try to check my math more carefully in the future.
