Real easy
>First of you'll need a video card that supports 2 monitors, or another video card.
If you're PC has an integrated video card (which means the video "jack" is actaully built into the motherboard) then it's only capable of one monitr and you'll have to get a second plug-in video card (which is like thos add-in cards you stick insode you coputer with the jacks pointing to the back.... like a modem, network card, video card, etc)
If your PC has a separate plug-in video card, it might already have dual-monitor output. It will either have two jacks, or will have one special jack with a Y-connector giving you two jacks.
These "jacks" I mention are either blue which is the older VGA analog monitors, or the newere white DVI digital jacks.
IF you PC has an integrated video card, it will likely have a blue jack.
IF your PC has a card, it will either be blue or white jack. If it's blue, there's like only one, if it's white there's a good chance it dual.
Please not that pluggin in a Y-connector to a video jack does NOT mean it can hanlde two monitors. If your video adapter is capable of allowing two monitors, it will either have two jacks on the back, or it would have come with it's OWN Y-connector.
So if your PC can handle two monitors, all you do is plug in the second one. Then the software that came with the video card (not the monitor) will allow you to choose how you will split/use your second monitor.
WindowsXP and Vista can also handle how the second monitor will be used, but if you've got one video card capable of handling two monitors, then their software is usually better.
If you have a computer with only one single-monitor video card, then you'll have to either get another single-monitor video card, and then use Windows to split/use the second monitor.
Or you can forget the video card you currently have, and buy a new card that can handle two monitors.
In my expereience, haveint 1 card with 2 monitors works a bit better ebcause the video apadter driver software does a good job of handle the split/use. But having two different single monitor video adapters will also work.
Hope this make sense.
Happy Woodworking!
