Lacquer allergy Question?
>I have been using lacquer for a finish as long as I have been finishing things. (Decades). I actually sort of like the smell. For years I have been using Deft in the spray cans. Now I am noticing that my nose is bothering me. It runs, and itches. The problem has been sporadic, but so is my use of Deft. I don't have a spray booth and have been doing small projects and ventilate when I can. I usually spray a bowl or hollow form and leave the area, going upstairs.
Does anyone know if this sounds like a reaction to the Deft? Or is it dry winter air? Or dust? Or just getting older?
Re: Lacquer allergy Question?
Try
>"All of the above."
mm
John E
>Lacquer would more likely be an irritant rather than an actual allergy (kinda splitting hairs, I know.) You might try a semi-controlled test - pick a day when you're fine, the spray some lacquer and see what happens. If you get symptoms, I'd let those clear, and then repeat - if it happens twice, odds are fairly good you may have your culprit. Obviously ventilation would help, but you might want to see your doctor - there are a couple nasal sprays that may alleviate or eliminate your problem.
John
>Don't worry unless you have hallucinations, unless, of course, you've always had hallucinations, in which case, dont worry unless the hallucinations stop.
Clint
Dont Worry, Be Happy
Mark Kauder, Phenix City, AL
>Barry,
I small point, the lacquer solids are in all probably not the problem, but one or more of the various solvents.
That said, I would suggest that without a booth, that you either 1) setup and exhaust fan (to the outside) that you can spray near, or 2) try and shoot outdoors - taking the room temp bowl and lacquer outside, shoot, and then go back indoors.
Part of what you may be reacting to in Deft, may be the Retarder. I know that when I add retarders to my lacquers (which I try not to do at all), the smell is much different.
Mark
Sensitizing solution
Michael Dresdner
>There are a number of components of aerosol lacquers that can be sensitizers. Unlike allergens that evoke a response with the first exposure, sensitizers may start out to seem fairly benign. As you get older and increase your cumulative exposure you can start to become more sensitive to them. Eventually you start showing symptoms that increase in intensity, and respond to smaller and smaller amounts of the culprit.
Two things appear obvious if you plan to continue using lacquer. First, you should wear a good respirator that blocks the components of the lacquer. Second, you should be spraying toward the fan of a booth.
You need ventilation when you spray, whether you are using a spray gun or an aerosol can. That can may look harmless, but it still produces a cloud of airborne solvents and particulates. When you spray, ventilate.
