Repairing Breadboard Ends
Paul Benton
>Hi,
I have large antique bookcase that has a small door, 17 1/2 wide by 15 3/4 high, that can be opened out to form a writing slope. It had some "breadboard ends", 2" wide that attached to the main panel via 4 dowels each side. As you might guess, the door has split and needs to be repaired.
Repairing the old, broken part of the main section is the easy bit, but I cannot figure out how to re-attach the two ends to 1) allow for movement, 2) avoid using some sort of pin that is traditionally used to attach breadboard ends as the door doesn't have them and 3) keep the ends tight to the main panel along it's full length.
Any suggestions
...Paul
