Website make-over... Opinions... *LINK*
HC Sakman
>Hi Everybody,
I just updated ("Tables" page is not fully re-done and "woods" page is not re-done at all.) my website. I am wondering a few things...
First of all, how does it load up? Do I have to go clickable thumbnail pictures that open up the larger picture in another page so the main page will load up fast(er)? Personally, I am on cable and no problems.
I would leave the rest of it to your obsevations and critiques.
Thank you all in advance.
Chico...
My Website
Re: Website make-over... Opinions... *LINK*
Kneale Brownson awaiting snow in N. MI
>Loads fine on DSL, Chico.
Larry Clinton At Frankfort (Central)., Indiana
>Chico, I have DSL and your site loads very well. I do find a few issues I personally would change. When viewing your gallery, after completing the review of "cabinets and Dressers" the "BACK" button takes you back to your Gallery. The other items - Tables, Seating etc. return to your home page. This requires that you re-select "Gallery" to view your other work. You also have a few Photo's in "Tables" and at least one in "Cabinets", that have had the background removed, these show up very poorly, at least with my computer setup. The edges are ragged and the photos just don't do your fine work justice. Other than that, I mostly like your site. Pretty easy to navigate and seems to have all the pertinent information. IMHO the only thing missing is some pricing. When reviewing sites for products I am interested in on the web, I normally don't go back to the sites without at least ballpark pricing. I think prices may get you more results (and only those you are interested in having reply).
JohnKJordan in East TN
>The pictures load fine here, but I'm using cable modem. I love looking at photos of your work.
I jotted down some comments as you requested:
1) The design of the opening page is clean and the photo you chose is nice. As it is your home page, I would suggest minor edits to the photo to remove some of the distractions on the ground. An example is attached, admittedly done very quickly with much room for improvement.
2) Some of the text seems overly large, for example the main title, some sub-menues, and especially the "back" buttons.
3) The text sizes and colors and treatment of the subpage titles are not consistent, i.e., "Gallery" is large and red, "Now Available" is large and grey, "Design & Craftsmanship" is small and grey (and doesn't match the main page where it is "Craftsmanship & Design"). Some subpage titles, such as "Publications" are underlined while others are not. (One web design convention reserves underlining for links.)
4) A personal preference: the header text on each subpage ("Sakman Fine Woodworks") might be more elegant if reduced in size to match the home page. (Also, it is missing on the "Gallery" page.)
5) The top photo and submenu of the "Wood" page differs from all the others and seems inconsistent.
6) This is a personal preference only, but I might try putting the subpage titles ("Gallery" etc) just under the "Sakman Fine Woodworks" header and just above the picture menu.
7) The "Wood" page seems inconsistent with it's white background. Also, if I visited the "Wood" page as a potential customer, I might not understand whether that page shows the woods you have used in your work, only those you will consider using, or something else (an educational page?) A note on that page might be useful.
8) The "Gallery" page text contains "S f W W" which seems oddly capatalized unless of course that is your logo, but I don't see it anywhere else on the site.
As you may see, as a retired graphic designer I love to critique things like this! All comments are worth what you paid for them. :)
Ron Hildreth
>Chico,
I, too, am on cable. You've got a great website! Everything downloads quickly, photos are VERY good, and I just wish mine was as good! Nice job!
Ron in Iowa
Two further suggestions:
Garrett in Victoria
>Hi Chico
1) On my monitor, the italics script you used in the Gallery section doesn't show well, even at 1280x1024 resolution;
and
2) The photos do not/not do justice to the quality of your workmanship. A little effort with a program such as Photoshop Elements would make them pop. Further, almost all the cabinets are distorted because they were photographed at oblique angles from above to show the tops as well as the faces. It's particularly disturbing with your lovely tables because the perspective makes the legs appear to taper inwards. If you cannot re-take the images, Elements 6.0 might enable you to eliminate some of that distortion using the original photos.
Cheers, Garrett
Bob Lemon Sacramento Ca.
>Chico,
I always enjoy looking at pictures of your work. They're beautiful!
To add to the comments of others.....your picture files are all over the place. You have some thumbnails that are larger than the large picture file. The master page pictures (top banner) has a total of almost 476kb. This in itself will slow the loading of the page. One of the pictures was pushing 330kb, I believe it was on the curly maple table top pic and it was a little dark.
When you adjust the picture size in your publishing program, it does not change the file size, therefore, the pictures should be sized before you pull them into the program.
I use PhotoFiltre for all my picture editing. This is a FREE program!
Bob
David Hay @ Denver
>Overall, it looks good. Some random notes:
1. I too was distracted by the expansion joint in the cement in the first photo on the main page.
2. Whatever character you're using as the separator between menu items on the secondary pages isn't in the font set I'm using on my linux system. It shows up as a lower case 't' (e.g. on the gallery page "TABLES t CABINETS & DRESSERS t SEATING t HOME FINISHING t DETAILS")
3. There's a lot of empty space, to my eye. You might keep a 1024x768 monitor size in mind when designing the site.
4. I personally would rather use a smaller font when you have large blocks of text (e.g. Craftsmanship and Design). To me, the large font is actually harder to read.
David
Thank you all. One confusing point though!
HC Sakman
>I see all the text and pictures in IE & Firefox EXACTLY as did in Frontpage. OK, Linux obviously doesn't like Frontpage's HTML. What else's out there? Have you seen these abnormalities in IE & FF or with some other browsers?
Thank you again.
PS: Yes that concrete expansion space (bench's picture) did bother me too.
Chico...
My minor quibble
Mike Circo
>First off, very nice site, much better than I ever could have done.
My issue.
In the galleries, you have the picture captions equally spaced between the picture above and below. I lose track of which picture the caption is describing. Very distracting and frustrating to have to figure it out each time I try to learn what wood was used in the picture I am viewing. Perhaps a line to separate each, or have the caption directly adjacent to the picture and a wider space before the next one.
Just what I experienced.
Mike
What concrete expansion space?!?!?!
>I don't see any concrete expansion space.
Happy Woodworking!
Alan Young
Re: What concrete expansion space?!?!?!
Alan Young
>Hey Mark- can you fix the small gap between my two front teeth?
The dentist wants too much $ :^)
Alan
Sure!
>Just send me a JPG photo and I'll do it for a tiny fraction of what a dentist will charge ;)
Happy Woodworking!
So, is this called "virtual dentistry"?
HC Sakman
>Thanks Mark. Gap filling looks good. Like it was never there.
Chico...
Funny story
>One of my very early clients does custom construction-type work. They gave me a bunch of photos from one of their job sites, and it had all sorts of contruction mess on it. Their crew left a hose in the grass, some buckets, some tools, a wheelbarrow, and they didn't get it all cleaned before they took the photos.
So I just photoshopped all that junk out of the photos and created some really clean nice looking photos on their website. When they saw them they were convinced that I had gone out to the site and had taken new photos.
Happy Woodworking!
Mark - did you miss...
>...the photo where I already removed the concrete expansion joint (up near the beginning of this thread) or did I just not do a good enough job for you? :)
Chico, if you need the help, I'm sure Mark or I or any of several others would gladly edit the original photo for you if you send it by email. (It's easier to do a cleaner job if done before the image is sized and compressed for the web.) As you can tell, some of us do this sort of thing for fun. It's more relaxing than when I did it for work before retirement.
Embarrassed.......
>Oooops.... no, I didn't see your post.
As happens once in a while, I opened the thread on my laptop at one location, left the browser page open, and when I reconnected at a different location later on, I didn't do a refresh, so the thread was stale. I've found that I do that too often. You think I'd learn after a while :) It's like when I email my sister, about 50% I send her an email about a website or something and 50% of the time I forget to paste the link in the body of the email. It's gotten to be a bit of a joke since I continue to do it so often.
Happy Woodworking!
Great minds
>>50% of the time I forget to paste the link...
Hey, at least you remember to send the email. I find messages in my out box that I've prepared and forgot to send a month ago.
Well, at least we prove that great minds think alike. Er, or is it forgetful minds, think..., Er, all is explained in the link below.
