OT Outlook problem
OT Outlook problem
OT Outlook problem
Howard Norman
>A problem has come up with Outlook. The problem is that any emails in the Inbox are lost when I switch to any other folder. By "lost" I mean apparently they go to that great big grave yard in space. I can't find them anywhere. This started a couple of days ago. Deleting and reinstalling Outlook did not solve the problem. I use AVG Free with daily updates and the computer is scanned every morning. Any ideas?
Re: OT Outlook problem
Jesper, Denmark
Jesper, Denmark
>Check your settings in Outlook. There is a setting that is something like "delete when read", which you need to change.
I am using a different language version, so it may be called something else.
Re: Slight Hijack, Outlook Express
Brian in Brighton
>Similar problem with my Outlook Express. Except my outbox is not always dumping to the sent items box. Any ideas? This usually annoys people as they recieve e-mails every 10 minutes when my send/recieve runs unless I manually put the e-mail from the outbox to another folder.
Brian in Brighton
I agree with original question. Should be in settings to "delete after reading e-mails". Look in you deleted folder to find them, unless you empty that when you close the program.
Howard Norman
>I do not find "Should be in settings to "delete after reading e-mails". I am using Outlook 2003. I have searched all of the options that I can find several times. That doesn't mean that it isn't there, it just means that I can't find it. I have searched deleted items several times for the missing emails.
Howard
Re: OT Outlook problem *LINK*
The MountainMan
>Hey Howard - try asking your question on this tech forum... when you get in - go to 'TECH SUPPORT GUY/FORUMS/INTERNET & NETWORKING/WEB & EMAIL' - There are lots of shrewd customeres there they will probably have the answer to your delima!!
Regards
The MountainMan
tech-help
David Yoho
>Tools - Options - Send
Is the box checked for - Save copy of sent messages in the 'Sent Items' folder?
