Re: DC question- pleated filter vs bag filter
Al Stokka - Cambridge, Iowa
>Marc,
I don't have a dust collector, but offer my experience with a similar situation in my shop vacuum.
For years, I have used a foam sleeve filter, sometimes, if used for dry pickup or fine dust, supplemented with a paper filter. I dreamed about having a pleated paper filter. When the old shop vacuum's cannister rusted through, I got the chance to try the pleated filter on it's replacemnt.
With the new vacuum, I decided to remove probably 30+ years of accumulated dust, dirt, pidgeon droppings, hay, and straw from my barn loft. I started with the new pleated paper filter but soon (less than 10 minutes) the intake airflow was reduced to an ineffective level. I had to remove the filter, beat it against a solid object (outdoors), reinstall the filter, and vacuum for another short time. After a few cleanings of the pleated filter, I decided to try the foam sleeve with paper overlay filter. Much better airflow over a longer time. When the airlflow finally decreased to an unacceptable level I was able to turn the vacuum off and whack the side of the vacuum with my hand to dislodge the dirt and dust, then continue the cleanup.
The pleated filter does capture more fine dust than the foam/paper filters, but the pleated filter clogged so quickly that I found it too time consuming to constantly clean the filter. After cleaning the pleated filter a few times with the whack-it-against-a-solid-object method, I had to blow it out with a nozzle and compressed air to remove the very fine dust. The foam/paper filter allowed very little fine dust to escape into the air.
I'd vote for the bag filter for your dust collector. No matter what sort of cleaning mechanism the pleated filter has, I'm betting it won't dislodge the fine dust that accumulates and gets tightly packed into the filter's pleats. Sooner or later you'll have to remove the filter to the outdoors and manually clean it with a brush or compressed air.
Al
