>This is not really about cleaning the sandpaper. I have been cleaning the abrasive for my Perfrmax for a while. (Using Simple Green or Venegar) My question is when to throw the sandpaper away. I notice the last pieces I sanded with 80 grit belts, the grooves left by the grits were round bottomed rather that vee grooved or sharp scratches. More effort to get the pieces through the machine and the machine tends to over heat.
At the price of the sandpaper for a PerformaX, I'd keep using it until I could then use it in my printer! LOL
Not long ago there was a thread about someone's 16-32 PerformaX poping the circuit breaker, and now you mentioning yours over heating. I have a 22-44 that I've literally tried to get it to do what you guys are complaining about, and it won't let me. Either the smaller PerformaX models don't have the automatic rate of feed control that keeps things like that from happening, or something else is wrong. Am I missing something?
>Ron, I'm not sure about what is going on, but I tend to agree with you on using up sandpaper.
I bought my my Performax used and it about 12 year old. When I got it the conveyor belt was worn and torn. I used it a while and it finally gave up the ghost. I replaced it and only then did I realize how badly worn the old belt was. It was pretty slick. I believe that was from sanding really thin stock and allowing the sandpaper to brush the drive belt and sand the grit off the belt.
I try to avoid this by running really thin stuff through taped to a platten or carrier. I usually sand veneer by running a backer peice through the sander to level it and then taping the veneer to it with double stick tape, back the sander off a little and sand the (Home Made) veneer.
Lately I have noticed my "new" belt has lost some grit. I think I have been a little slack getting the abrasive tight on the drum and I now have a slick spot near the motor side. I need to do better or use the carrier more. I made some plys for bending laminations that were about 1/8" and I think that is where the damage came from.
I now notice that the machine will over heat and cut itself off. I was wondering if this were from using dull sand paper or if the motor is aging or if the cutoff switch was becoming more sensitive in it's older age.
