Motor Size for compressor
Tom Norton
>I have a lead on a compressor,Craigs List, that is (-) the motor. What size motor would work? The guy wants $39 for the tank and compressor.
Tom Norton
Depends
>On the size/output of the pump. You can run a 3 cfm pump with a 1.5 hp motor, but that won't crank a 6 CFM pump. Plus compressor motors are set up and rated for compressor duty with extra energy being put into the start phase to overcome the initial resistence of the pump sitting in compression mode. Then you have to factor in the type of pump, oil-lube, oil-free, 1-stage, 2-stage . .
If you want the right answer, get the specifics on the compressor by brand, model and type and then call a compressor or electric motor shop in your area.
good luck!!
mm
Agree, and...
Grant in Iowa
>Consider why the owner took the motor from the unit to begin with. I think it is unlikely that a working compressor was cannibalized for the motor (unless the bad motor is on the unit still, and is bad--not sure based on your description).
Make sure you check the unit over carefully for things like:
A rusted tank (evidenced by pin holes un the lowest part of the tank, or bubbling paint on the bottom, or the like)
locked up compressor pump (turn it by hand and it if seems to get compression, then it is probably OK)...look for an arrow on the flywheel for turning direction, or know that the air fins molded into the flywheel usually are configured to push air over the cooling fins on the motor, and spin it accordingly
make sure all of the parts are present. Line from the compressor to the tank, should have a check valve in it (may be part of the tank fitting)...this could also be bad, but no good way to tell until the unit is operational. Regulator, air pressure guage, air fitting, etc should all be in place and undisturbed. Pressure switch with power cord should be in place. Is it 120, or 220VAC? If it is 120, then a compressor duty 1.5 HP motor would be sufficient, since that is all you can usually power from a 15A circuit.
I think that unless this unit is a cast iron or cast aluminum compressor pump with large belt driven flywheel, and all of the parts are present, then I'd pass on it for any price except free. If it is an oil bath cast iron or cast aluminum compressor, then set your price based on the cost of repair parts(including a belt, and pulley), plus a fair amount for your time. Also bid your price knowing that all the risk is yours, should something more major be wrong.
Proceed cautiously, let us know what the information is on the labels on the unit and we can probably be of further assistance.
At worst, it may be nice to get the tank for use as a vacuum pump reservoir if you hope to ever get into vacuum clamping or veneering, but that should be free, if that is all you get.
Regards,
Grant in Iowa
