Motor - electrical - help?
>Have tried every which way to get this DC motor to run or even hum. NG
Since the unit has its own switch that was always on, I'm wondering if it got bumped and broken, so I'd like to try to bypass it since the DC works off a remote switch and contactor set-up anyway.
Here's the rig: the two line hots go to the switch. Then 2 yellow jumpers go from the switch to the white and red leads from the motor with the motor's black and yellow lead wires spliced.
Here's the question: To bypass the switch, do I simply connect the hot leads to the two yellow leads?
Thanks anyone!!
mm
Re: Motor - electrical - help?
Never Mind . . .
>When I pulled the hot leads off the back of the switch, the plastic box just fell apart.
Wired the two hots to the jumper leads and hit the relay switch. . .
It lives to suck again!!!!
mm
I was going to ask…
Rod Peterson -- Ormond Beach
>Did you have both leads disconnected?
Rod
hanging his head but it had to be said…
>The OEM dpst integral switch failed to reconnect one or both of the conductors, consequently the facility switch which activates the contactor control to interrupt all the dedicated circuit's conductors, is now the primary switch for the motor.
[Or something like that]
Re: I should have said *LINK*
Kneale Brownson awaiting snow in N. MI
>Kind of like this guy, eh?
http://www.youtube.com/watch?v=osD2U-s8i6E
Ummm, Maybe
>But working with juice is really different from working juiced.
mm
[looking at snow in N. Jersey]
