What'd I Do?
What'd I Do?
What'd I Do?
>Got my DC impellor back from the shop and reinstalled it in the blower and motor unit, plugged'er in and hit the switch . .
Duh, nuh thing in happen ning.
Cehcked the dedicated circuit . . fine.
Contactor relay is hot and humming in the "on" position.
Unit (integral) switch is "on."
Nuth-thing . . motor doesn't even hum so I have to think there's no juice getting to it.
Now, I did have the centrifugal switch off because the spring plate was making a squeeking/ticking noice when turned that sounded like a motor bearing. Cleaned the parts off with a bit of air and reinstalled the switch to the very same depth and position on the motor shaft as before.
Motor was running just fine before this so I have to think I did or didn't do something here.
Anyone got an idea?
[No, I don't have any parts left over |;-}} ]
Thanks
mm
Re: What'd I Do?
Re: What'd I Do?
Thomas S Stockton
>Mark,
If you took the centrifigul switch off you might of mounted it in a different position and it isn't doing it's thing. I can't remember exactly how they work but if you take off the end housing it is pretty clear how it works.
Is it hard wired or plug in could be a loose connection someplace poke around safely with a voltage meter and see where theres power.
Tom
