Re: OT Rats in crawl space/insulation follow up *LINK*
Dan Mitchell
>Barry - Thanks for the reply. Your responses are very helpful. Glad to hear it's not the worst, I can say it's the worst I'VE seen, but since that's only about 3 such spaces, I guess that doesn't mean much! I did have the home inspected prior to sale, the inspector didn't seem to think it was a big deal, either.
Most houses in Seattle don't have AC. We have a heat pump & being heat intolerant I do run the AC, though not nearly as much as I did in Ohio. Summers are much cooler & much less humid. Interesting about the insulation vapor barrier. I wonder if, given the possibility of moisture from the ground & moisture from a heated space above, vapor barrier on BOTH SIDES might not be good. If there is such a thing. The ducts are 6", a bit hard to tell in the pics. I had never seen the bare insulation wrap before, I can tell you it's a royal PITA when you bump your head into it while working in the dungeon!
I know the plastic ground cover needs to be replaced.
I haven't noticed mold either. The space smells a bit "earthy", but not really bad. But I generally wear a respirator down there. I imagine in Virginia mold could be a real issue. People talk about Seattle being rainy, in fact it ranks about 40th as a city in total annual rainfall nation wide. I do think the standing water was unusual, though the front grade definitely slopes toward the house, with a 2' depression near a fireplace that juts out, bay-window style. Looking at the terrain, I'm thinking you'd have to install a drain in this depression, since the road is actually higher than the floor of the house at that point. Plus amazingly, the wall has siding on it as it goes down in the depression, so you couldn't just fill it in (who designs this stuff?).
On the rodent front, when I took the pics & walked (crawled) about 2/3 of the perimeter, only say maybe 15 droppings, all hard. I have 2 bait boxes outside with single feed commercial poison (link below). They are getting more hits, with the colder weather. 4 traps in the space are thus far undisturbed (except by me, I put my hand in one yesterday while down there. Good thing I was wearing a glove! Still hurt like hell...
Your observations are invaluable Barry. When you're paying someone, it's so hard to tell what their true motives are. I really appreciate it!
Dan
Final blox
