Water Base Over Boiled Linseed Oil
Tomm
>I used one coat of boiled linseed oil on a few small projects and I was wondering if I could finish them with water based poly after they dry. Thanks for your thoughts.
Re: Water Base Over Boiled Linseed Oil
Rob Stokes in North Vancouver
>I'd put a barrier coat between them - Sealcoat should work well. But I'd also let the BLO cure, not just dry. It may take several weeks to do that.
Rob
Pat Riley
>I have done this on several small items with good results. You do have to let the BLO cure for about a week to 10 days though.
Glenn Madsen near San Francisco
>Why use the waterbase and have to wait, or use a barrier coat? Use the oilbase, and start many days earlier. And I find it much easier to wipe on, too. Quite like using the BLO you started with, particularly if you thin the oilbase poly with about 25% mineral spirits.
