Veritas - Innovation in Tools
CO2/ Air Nail gun/Paint Ball Questions
>Someone posted a response about the CO2 system at Lowes that indicated they were using Paint Ball gun canisters to power their nail guns.
I know nothing about Paint Ball guns or paraphernalia. Can someone tell me a little more about the CO2 canisters for paint ball guns? What type of fittings do they have and how can they be adapted to other applications, such as nail guns?
Re: CO2/ Air Nail gun/Paint Ball Questions
I Wonder If They Can Be Used
>Good Morning Barry,
....to color the nails. :<)
George
Re: I Wonder If They Can Be Used
paul waddle
>Thats a good un Colonel! pw
Glenn Madsen near San Francisco
>One of my sons used to be part of that hobby. He had a carbon-fiber air tank, about a quart in size, that powered his gun. NOT CHEAP. It seems it was tested/rated at 10,000 psi, IIRC, and I may not. Had it filled at the diving services shop here in town.
When you consider that I set my finish nailer at less than 100 psi, there are some things to factor in beyond simply screwing on the tank.
Loading up non-refillable CO2 tanks might be quick, but I can't see it being cheap over time. It would be quieter than that blasted air compressor, though. It's a nice thing that glue is quiet.
Thomas S Stockton
>Barry,
That was my question, I don't know what fittings are involved to hook up a paint ball tank but I think the time and effort involved would be more than the $89 lowes charges. The tanks are probably steel or aluminum and you can probably get them refilled at a number of places. No idea if you have to stick with co2 or will staright air work. They are probably filled at a pretty high psi 2500 or so like welding tanks.
Glenn I agree I think it would end up being expensive in the long run but for installations were only a few nails are needed it would be worth it in weight a space savings especially if you have to lug stuff up or down stairs.
Tom
Scott Crumpton
>That was probably me. Actually, it was rather easy to make. The CO2 canisters at Lowes are relabeled paintball canisters and are re-fillable. I don't remember the CO2 pressure, but it's too high for most normal shop type regulators, so you have to bring it down some. For this, I used a standard paintball remote regulator (mounts on the pistol grip and screws directly on to the can, making the can your stock) that I got on ebay. I adjusted the regulator down to about 150psi, but it's not accurate enough at low pressures for use with tools. From there the gas goes through a section of high pressure coiled paintball hose to the second regulator. This regulator is a small HF unit with gauge to adjust the final pressure. A quick connect is atteched to the outlet and feeds the tool directly.
A safety note about CO2: It's a strange gas in it's "liquid" form. Doesn't really qualify as a liquid. Never ever fill a CO2 bottle more than 1/3 full by volume. If you do, you risk an explosion or venting if the temperature gets into the 80s.
---Scott.
OK, I lied, what I am really trying to do is.....
>Use CO2 to blow water out of piping to winterize houses. As a Home Inspector, things are slow for me and I thought this might make a good sideline until things pickup. (Somebody please tell me things are going to pickup.)
I have a friend who uses a pancake compressor to do this, but he also carries a generator. (You can't count on the power being on.) I have a compressor, but not a generator. Doesn't make much sense to buy a generator for an experiment to see if I can pick up spare work.
Anybody got a better Idea? Local plumbers use the little CO2 cartridges that go in air rifles. Got to find a way to support my wood working habit.
Re: Barry - another option
Larry Clinton At Frankfort (Central)., Indiana
>I have a MIG welder with Argon/CO2 mix. Tractor Supply (and a couple other places in Central Indiana) sells a smaller tank than I have for a reasonable amount. These are then returnable for exchange. The Argon regulators are also reasonable (for the cheaper ones). This type tank would be somewhat heavier than the paint ball tanks - but I would guess they would also hold a lot more gas. You may want to check prices - Also some places handle nitrogen - may want to investigate. As you probably won't be lugging the tank around like you would with a nailer, these may be feasible.
>Hmmm? Many years ago I used nitrogen to power my construction staple guns. We could staple on a hundred sheets of plywood with a $15 l'tank of nitrogen. I still have the regulators. The problem was that the nitrogen cam with about 2200 PSI in the tanks and the gun manufacturers were afraid the regulator would fail and pass tank pressure through to the gun, blowing it up. They forbid us to use the system anymore.
I think the reason they permit CO2 is that it turns into a liquid at a much lower pressure and remains pretty much stable.
I will look into this. Thanks. Wonder if regulators go bad just sitting n the shelf?
Re: OK, I lied, what I am really trying to do is..
Scott Crumpton
>Well, that makes the whole problem easier. One of the leftover parts from my CO2 adapter project was a paintball bottle filler adapter for lack of a better term. This little item allows you to connect a bottle directly to a hose with no regulator. It has a screw in plunger that opens the valve in the bottle. Attached to it I have a brass hose barb. Soldered into the end of the hose barb is a small section of brass tubing that I squeezed down to a very small orifice to restrict the flow into a short length of vinyl tubing. I use this rig to release small amounts of CO2 into opened varnish and polyurethane cans. Prolongs the storage dramatically by displacing the O2 from the can. It wouldn't be too hard to construct such a rig for a larger CO2 bottle. The only problem is that the hose tends to freeze and become stiff/brittle. I would not attempt this with anything other than CO2. CO2 is in the 1000psi range, most other gasses are 2200-2400psi.
They can be rebuilt
woodenleg
>My local NAPA store can send off regulators to be tested and rebuilt.. They also can sell bottles of gas or rent them. I would check with a local welding supply house. Just be careful you give them the same idea you have. Dave
