Dead Blow hammer question?
>I see David Marks and Norm give it a whack with the Dead Blow occasionally. (Norm was really whaling on a shelf recently) It was mentioned again in the Woodcraft Mag.
Anybody got any experience with one? I have seen them, but never bought one. Are they worth it? What do they do for you a regular hammer won't do?
Re: Dead Blow hammer question?
>I use mine often. When persuading perfectly cut pieces to join the way they are supposed to (rather than leaving "slop space" in the joints). Mine's made of urethan and will not mar the surface being hit provided you keep the head clean and smooth.
HF sells them for $2-3 in their "Inventory Reduction Notice" things |;-}
Carol - now in NC Nebraska
>I have both sizes, Barry.
They are my finesse tool of choice. Truly. Very controlled bumping and still capable of real whaling!
Egad
>Carol,
You go Whaling with a hammer? Geez, most use a big boat and harpoon. I'll bet you have to real wail on them, eh? So THAT's why they call it a "dead blow" hammer!!
[Sorry, couldn't resist. You can now lay in wait to get me back; shouldn't take long.]
Paul Woolson
>I call mine "The Convincer". And it does a fine job of convincing tight joints to go together. I used to use a hammer and a block of wood but find that the weight of "The Convincer" gives me more power with more control. I'm not blindly wacking at the part.
Ron Hildreth
>Barry,
I love my dead-blow! Rubber coated, it leaves no marks, is heavier than a rubber mallet, and most importantly, is filled with steel shot that concentrates the enertia(sp) from the blow, with no rebound. It all boils down to the fact that you don't have to hit something as hard to get the same results.
Ron in Iowa
Jesse Cloud
>Here I am again being the contrarian, oh well...
I wouldn't use any hammer, deadblow or not, to close a joint. Good way to crack the piece. If I can't get it together by hand, I work a little more on the fit.
However, once the joint is tight in a dry fit, a deadblow hammer is the preferred way to dissemble. You can knock the pieces apart gently and in a straight line. If you wiggle them back and forth by hand, that can wear the joint and that nice tight fit becomes a loose one.
I rely on two.
Dave Bair, Eaton Rapids, MI
>Number one is a shot-filled number that also works well when setting pavers, just don't use it on wood again unless you pick out the bits of sand from the head first.
Number two is a hockey puck. It's great for situations where a tap or two is all that's needed or you're trying to get two edges flush. It will leave black mark if you deliver a glancing blow, however.
Thomas S Stockton
>You guys have better luck than I do, I use a homemade clamp pad under mine. No matter what anybody says the will dent the wood. The harbor freight ones are an amazing deal and as good as the expensive ones.
Tom
Dead Blow Hammers Settle Arguments
>Before they start. :<)
George
Kent in Emmaus, PA
>I have a pair (1 and 2 lb, I think) and they get used for just about every schwacking task other than the actual driving of nails. Besides assembly and disassembly, deadblow mallets are great for tapping or pounding chisels, prybars, etc.
With the holiday season upon us, I ought also mention that they'll serve as substitute maracas when a spontaneous conga line breaks out at your next social or business function.
