Cutting Aluminum
Rod Rentz
>I have seen a couple of wood plans that use aluminum angle stock for trim. Is it difficult to cut?
Cutting Aluminum
Rod Rentz
Re: Cutting Aluminum
Virgil Johnson
>Describe cut. I just cut some 1/4" 5/8" and 1/2" plate this weekend on my bandsaw. I've cross cut Alum. on the table saw 1 1/2" square (won't do that again) Cut 1" thick fixture base plates plates out of a 4' x 8' sheet of alum. with a skilsaw at work. Angle should pose no problem. Use a bit of WD 40 for lube.
Jesper, Denmark
>Hacksaw and a little kerosene or WD40 for lubricant - easy
>I cut aluminum and copper on my Delta 14" bandsaw with a 3 TPI bimetal blade I was using for woodworking. It worked well enough, but not sure I would do it again. One be sure to wear eye protection, if you think saw dust in the eyes is bad, you don't even want to think about metal slivers. And brushing and picking the metal slivers out of the rubber tires on the BS was a PITA. And their might be a greater chance of a static spark from the DC, but I am not sure about that.
Bruce, a MN Galoot
>In addition to the very good advice on face shield and goggles, this is one time I'd find a way to use gloves, if you can keep your hands away from the blade. The little pieces that come off the blade are VERY hot.
Bruce
easy
John in New Mexico
>As Jesper said, hacksaw, then file the cut clean - file clogs quickly leaving big scratches, so be sure to get a card (one of them short bristled wire brushes) for cleaning it.
I also cut it with a chopsaw, won't hurt the carbide. For daily cutting you use a negative hook blade, but most blades work fine for a cut here or there. It is not pleasant though! I've also cut it with a router, works great, but its a good idea to put ear muffs on over your ear plugs!
ScottS
>The other guys have given you the basics.
Aluminum cuts easily with just about any carbide-toothed blade. If you're going to make lots of cuts, there are special blades designed specifically for cutting aluminum. While I normally cut metal stock on a metal-cutting band saw I've made the occasional cut with my miter saw (using a 40-tooth blade; haven't tried the Forrest yet). Chips fly everywhere, they're sharp, and potentially hot. I'd be worried about sending hot metal chips into a dust collector or Shop Vac filled with sawdust! While I wouldn't wear gloves while using the saw, I try to make sure that as much of my body as possible is out of the "line of fire". I've also cut plate with a jigsaw equipped with a bi-metal blade. Won't do that again; too inaccurate.
FYI, if you buy your aluminum from a full-service metal dealer rather than a big box store they'll often make accurate cuts for free/cheap using their band saw. Just be sure to let them know how precise their measurements need to be! My local shop normally makes cuts that are within plus or minus an eighth. If I ask, however, they'll take the time to make sure they're dead-on accurate.
Joe Doker
>One thing that wasn't mentioned that is important, if using the chop saw, BE SURE to clamp the piece securely so it can't move during the cut. A slight movement of the piece can really jam the blade.
Addition.......
Jesper, Denmark
>The old trusty angle grinder with a metal blade or disc works fine to....dry.
