Have a question? Ask Woody!
Anyone tried to cut up a sofa cushion?
>I made a doll's crib and my girl friend is trying to make a mattress for it. She has cut up a sofa cushion, but it did not come out as smooth as we would like. (I know, I know. We should buy one but the pack rat gene has kicked in and she is trying to salvage the cushion.) So we need to "resaw" the cushion, down form about four inches to two. Any suggestions? Anyone tried cutting one on a bandsaw? How about running it through the planer? :)
Re: Anyone tried to cut up a sofa cushion?
Jason Roehl in Lafayette, IN
>Draw a line around it with a Sharpie for a guide, don't compress it, and use a brand-new blade in a utility knife. Don't try to cut deeper than the length of the blade. Cut at a very shallow angle (draw the knife across the foam).
Another option: do you have an electric knife (hobby stores use something similar when they cut foam to sell)?
Jason
Not sure what your size is but . . .
steve mackay
>I've allways used the 'lectric carving knife. Nice & even and won't tear. Doesn't get warm enough to stick to / between the blades. But, them, never admit to useing it to anyone else in the house.
Brian Hahn in SW Wisconsin
>I use an old butcher's knife sharpened with 100 grit sandpaper. Slice with the knife at a shallow angle and take multiple passes. The rough edge acts like a very fine tooth saw blade and gives a clean cut. I learned that trick many years ago from my Dad, who was an upholsterer (tack-spitter) for a good number of years.
Motorcycle seats
>I always cut the foam for motorcycle/gocart/golfkart seats with a razon blade.
Happy Woodworking!
Sure, Barry
>Good Evening Barry,
Those who recommended an electric carving knife are right on. I used one when I did preofessional upholstery a few years ago. Perfect for your job.
George
Paul Woolson
>I've resawn on the bandsaw quite a bit. You just have to be very careful you don't compress it as you push it through. I've always had very nice results.
Planer? That scares me, I'd avoid that one.
Bandsaw. But first.
Virgil Johnson
>Put the blade on upside down and it will cut pretty smooth without grabbing.
Re: I cut off Barney's head, bad news?
Brian in Brighton
>When a lump of stuffing went into the blade it actually jammed it pretty good. Not sure what foam would do though. They use a wavey blade to cut it at the local foam company. I would try to sandwich it between some plywood and use a serrated kitchen knife.
Brian in Brighton, with one decapitated Barney doll.
Grant in Iowa
>So long as the cushion has no batting and is only foam, the BS works great to cut it. Fast, perfect cut, and I have never had any issues with grabbing.
It may be prudent to use a blade with fine teeth, but beyond that, no worries...
Regards,
Grant in Iowa
My dog did....
Andy Halterman: Bad day to stop sniffing glue
>Into lots of little pieces. Came home to find foam all over the floor and a happy mutt so proud of her accomplishment.
Have no idea how this relates to your question but I thought I'd share. :-)
Andy Halterman
Hopefully I'll have time to ride this afternoon in Hendersonville, NC�
John McGaw
>In all but the most squishy-soft upholstery foam I've found that an electric carving knife does a good job. Must confess that I've never tried to "resaw" foam this way but "crosscutting" with the ole' turkey-slasher is very easy.
Turkey-slasher . . . ROFL !
steve mackay
ScottS
>You're not alone. I one rode down the the Corbin factory in Hollister, CA. to have a custom motorcycle seat made. They, too, used an electric knife when cutting foam.
waroland
>If you don't have an electric knife a bread knife works great.
Doug Turner
>That's what wood shavings are for - ideal doll crib matress stuffing.
Yeah, but.......
>the feathers got all over the place.
Clint
DWBH
Re: Yeah, but.......
Pete in Holland, MI
>2 thoughts:
1) When cutting "foam rubber" with a knife, keep pulling the kerf open so as to reduce the friction on the side of the blade, which slows it as it cuts thru.
2) Have also seen foam frozen, then cut on a saw. Much easier to cut when not bouncing around.
