Veritas MarkII Vrs. WorksharpWS3000
Howard
>I�m considering either the Worksharp WS3000 or the Veritas Mark II power sharpener. I�ve seen some good reviews on the Worksharp but have not seen any reviews comparing the two machines.
Which one would do a better job for just sharpening chisels and plane blades?
Thanks
Howard
Re: Veritas MarkII Vrs. WorksharpWS3000
Garrett in Victoria
>Both do a fine job.
The essential difference is the tool holder/guide. The advantage of the Veritas guide is that its holder enables use of the entire abrasive disk. OTOH, it's fussy to set up. The advantage of the WorkSharp is that its guide sets up automatically and is foolproof, but it's confined to one area of the abrasive disk.
Take your pick.
Cheers, Garrett
Bill White
>Makita. Tried and true.
Bill
NickB
>No direct comparison for you, but I've got the Veritas sharpener, and I don't find it fussy to set up (there is a jig for setting the blade in the holder). I spend more time changing the platters (as I move through the grits) than I do anything else.
I don't know if the Worksharp does this, but the Veritas makes putting a micro bevel very easy (there are two different platter thicknesses-using the thinner one for the last couple of grits results in a microbevel).
I bought my Veritas not long after they started making them-I wasn't sure it would be worth the expense for me (as it turns out it most definitely was), but I took comfort from Lee Valley's excellent return policy. I like the machine, and I was even more taken with the machine (and Lee Valley), when a cover for it showed up in the mail (they did not include a cover when I bought my machine, but when they added it to the kit, it appears they tracked down earlier purchasers (mind you, I had moved from CA to MA in the meantime) and sent them out for free).
Hope this helps,
Nick
HC Sakman
>Grabbing the center brass nut really speeds up changing plates in Mk-II LV Sharpener.
Chico...
I forgot to say: "while plate is turning"
HC Sakman
