>I have a Craftsman 10" Contractor's Saw Model 22114. I would like to install PALS in order to make trunnion adjustments easier but from what I can see, the trunnions are sandwiched between the table top and the top flange on the cabinet.
Since the table has a flange on the edge it looks like getting to the trunnions is pretty difficult.
Am I wrong about this? Has anyone installed PALS on this model saw?
>I believe that's one of the newer TS models made by Orion. The PALS are for the older models made by Emerson. IIRC, on your saw the trunnions attach to the cabinet like a cabinet saw. In which case, you don't need PALS for alignment.
>Frank, I also have that model, and have made adjustments to mine . You do not need ths PALS. All you need to do is loosen the bolts that hold the table to the cabinet and nudge the table ever so gently in the direction you need. First determine whether the blade is angled right or left in the slot (viewed from above). If left, slightly tighten the table bolt on the left front, and then bump it forward using a dead-blow mallet to rap the right rear corner. Similarly, If the blade is angled right, slightly tighten the right front bolt and hit the left rear corner to move it forward. DO THIS CAREFULLY, IN SMALL INCREMENTS, CHECKING FREQUENTLY! It will not take much movement to correct it. If you don't leave one bolt a bit snug, you can go too far too easily, and end up taking a lot more time than is necessary (speaking from experience, there). Hope it works for you. Let me know how it turns out.
>You're in luck! PALS aren't made for the 22114 or 22124 and aren't needed. Your saw is a hybrid with cabinet mounted trunnions and an internal motor. That's one of the better features of that saw IMHO. Traditional contractor saws have outboard motors and table mounted trunnions. The cab mounted trunnions are pretty easy to adjust. Just be sure to loosen the table bolts and not the trunnion bolts, then adjust the table to the blade.....not the trunnions to the table like a traditional contractor saw.
In-Line Industries makes an alignment system for contractor saws that makes it easy to align the blade to the miter slot on table saws. Here's the link to their web site;
