AutoCad Question
AutoCad Question
AutoCad Question
Bill Tindall, E.TN
>How does one import a jpg picture file into autocad to work on dimensioning the image?
Re: AutoCad Question
Which version of Autocad?
Tim Greif - West of Chicago
>Depending on which version you have, the procedure may be different. In Autocad LT, it's pretty cumbersome. I don't have LT but I do use 2005 and 2007 regularly.
In Autocad 2005, goto Insert...Image Manager. There you can browse to a jpg (or any other type of raster image). Keep in mind, this is essentially an X-ref (external reference). The image is linked into the drawing, not actually inserted.
I haven't had the need to do this with 2007, but I believe it's part of the X-ref manager now.
Otherwise, just try the IMAGEATTACH command.
I'm sure you know the drill for scaling the image, but if not, here's the way. Make sure you're in model space. If you know one dimension in the image, draw a line of that length in model space. Then attach the image. Put one corner of the image with the known dimension on the end of the line, then scale the image up or down until the other corner of the known dimension matches the other end of the drawn line. You can now use the measure tool to scale off the other dimensions of the image.
Good luck.
Re: Can't, not with jpg
Brian in Brighton
>It is a linked file so the dimensions have nothing to grab onto. It will become clearer when you insert it and see the window around it. It's like a picture in Word, just an image, not something you can work with. Unless the newer version of AutoCad is a lot stronger than my 2002 version.
Brian in Brighton
piece of cake
Bill Tindall, E.TN
>Turns out I can just copy and paste the picture into the Autocad screen and stretch it to whatever size is needed. Now to figure out how to get dimensions on it. The next step is to make a vertical line 38" tall on the edge of the piece, or make a vertical line 38" tall and stretch the picture to line up. This is going to turn out easy when I learn the steps.
Re: piece of cake
JohnKJordan in East TN
>If you simply want to add dimensions to a bitmap image an image program like Photoshop should work nicely. Photoshop will draw lines with arrows on the ends.
Of course you can, I just did it.
>I don't know about Acad 2002, it's been a while since I used that version. Just insert the image with IMAGEATTACH command. It comes in as an X-ref. Yes, you are correct that it's simply an image that you can't modify. But you can certainly scale the image up or down in size. As long as you can do that, you can scale dimensions off an image, neglecting any parallax or perspective errors.
Think of it this way. You're in your garage with an inflatible miniature model of a six foot tall chest. You can make the miniature chest any relative size you want by adding or venting compressed air to it. You know the height needs to be six foot. So you take out a six foot carpenter's rule and stand it up. You then add air to the model until the height is exactly equal to the carpenter's rule. You now have a scaled up model on which you can measure all the other dimensions.
This is exactly what you do in Autocad. You have an image of a chest that you know is six feet tall. In model space, draw a full size line of that known dimension of the piece, a six foot high line. Then insert the jpeg image. Now you just scale the image up or down so the line and the side of the image are the same. Just play with the scaling until they match. You can now use the DIST command to measure the length of any other image element in the X-Y plane. You obviously can't snap to actual object intersections in the image but you can get close enough freehand to determine the dimensions you need.
>What Tim is describing seems like it would work well. You would not have points on the image that acad snaps to, but you would be able to dimension it by zooming in on the pic and dimensioning with the snap turned off.
>I just tried this with Autocad Lite 2000 and it works fine. The only concern when taking dimensions off the pic is that the angle of the camera affects the actual length of the item, but if you wanted to take a design and start with it as an idea it should work fine.
Re: Of course you can, I just did it.
Ralph
>Tim's right, I do this all the time when I'm given a print version of something that I need to import into Acad. I'm given architectural drawings on paper that I need to scale to size to put our equipment into, so I scan the drawing, insert it into my template and as long as I have one known dimension, I can scale it to the correct size.
Ralph
