ADVERTISE HERE - FREE TRIAL
Porter-Cable 310 - fence, and collet sticking?
Bill Houghton, like MN today, Sebastopol, CA
>Does anyone know of a good, and reasonably priced, aftermarket fence for the Porter-Cable 310 trim router/laminate trimmer? My old Ryobi TR-30 (built back when Ryobi made good tools, quite some time ago now) has one, and I've come to find it quite helpful. I fear that eventually, I'll no longer be able to get parts for the Ryobi, but assume that parts for the 310 will be around for a while yet (I picked mine up for $20 at a garage sale, although it came with the tilt base, and I'm getting ready to buy the regular base - still cheaper than retail).
Also, it's suffering from sticky collet. Any good suggestions for a cure appreciated.
Re: Porter-Cable 310 - fence, and collet sticking?
HC Sakman
>I don't know about the fence for PC 310, but you need to hit (gently but firmly) the flat side of the collet nut to make it release the bit.
Chico...
And remove the bit before putting the router away.
Garrett in Victoria
Paul Waddle
>I don't know about this particular router,but for sticking bits,I hit the bottom of the bit with a pc of wood(like i'm driving it deeper into the router). I think the vibrations losens the bit-don't really know but WORKS!
Carol - now in NC Nebraska
>Whacking on the collet nut or the router bit will usually work. But the force is also transmitted to the bearings.
So, once it is apart, thoroughly clean the collet, the socket, and the nut. Use a solvent, like mineral spirits. Allow to dry. I don't use a lubricant like WD-40, etc. Somehow friction fit and lubricant are at cross purposes in my book. :)
Also check the router bit shaft. If it is scored, replace the bit. And remember, collets are consumable items. After a while they need to be replaced.
In any event, the usually culprit is gum resins from the wood. So cleanliness is a good thing.
from the Rouerlady (retired), now into turning. :)
Bill Hylton
>The 310 is well-known for its death-grip on bits; I've never heard a solution other than what's already been suggested--whack the collet nut with the wrench.
As far as an edge guide, I'd look first at Porter-Cable's products to see if they sell something that fits the 310. Failing that, look at Microfence. It's the best edge guide on the market, and it can be adapted to fit just about any router you may own. I use my MF guide on my 310 as well as DeWalt, Milwaukee, Bosch, PC and other routers. Price is reasonable for what you get. www.microfence.com
Bill
>Bill,
Whack the collet nut to loosen the bit. That is what PC tech support told me to do years ago and it works fine. As bill mentioend, clean the collet and nut well. That does help.
I don't have an edge guide for mine, but if I neede one, I'd make it from thick plexiglas or wood and a couple steel rods of the appropriate diameter. Since teh 310 does not have a place to mount the rods, I'd make a custom baseplate which is a bit larger than the unit and glue or screw on something to hold the rods.
Glenn Madsen near San Francisco
>No edge guide on mine. The base is from www.patwarner.com, and it's a nice one. I suspect I'd build a replacement base out of 1/4" plywood, and secure the edge guide to that with screws.
At my shop, this is one of four 'little routers', and the favorite, even though the others seem to have more features. This one is more solid. No, I paid more than '$20 at the garage sale' for mine. Would have had to go to a garage sale first. You got a good deal. That little router will likely outlive you still.
