OT - Sealing around sewer pipe to exclude rodents
Dan Mitchell
>Last spring, we bought a house in a suburban area on a 1 acre heavily wooded lot. When we bought the house, the previous owner had a Terminex contract for previous rat activity in the crawl space. The company stated in writing no rodent activity at the time of purchase. I had another, independent exterminator inspect the house for rats right after we moved in, again, no signs. There were several set and baited traps in the space, which I check periodically as an indication of new rodent activity. This afternoon I went into the crawl space & noted a dead rat in a previously set trap. At the time my inspector was here, he suggested cementing around the sewer pipe where it exits the crawl space, something I have not gotten around to doing. Looks like I need to do that now ;-/ (horse gone, barn door CLOSED... ). So, I'm wondering, what should I use to seal this pipe. I have not seen the opening myself yet, I'll check it tomorrow, but I'm guessing it's typical of what you'd see, probably a gap of 1/2" or less. My inclination is to use hydraulic cement, which I have used for such jobs in the past. I think however the pipe may be plastic (all internal drain pipes are PVC, never lived in a house with this before, so I'm not sure if this generally transitions to cast iron before exiting the building). If hydraulic is not the best choice, what would be? Sorry for the length on this & thanks in advance for any advice!
Dan
Re: OT - Sealing around sewer pipe to exclude rodents
>Dan, I looked this up in the 2003 International Residential Code Which was probably not ensue when your house was built, but is probably similar to whatever code was in effect. Actually, it may be some what more rigorous, but I don't know when your house was built or whatever Code was in effect.
As far as I can tell there is a concern that there will be some type of differential movement between he pipe and the foundation. Currently, a sleeve is required through the foundation. The sleeve is to be a pipe at least two sizes larger than the pipe. This is in the section for pipes passing through the footing or foundation. In this section there is no reference to filling the space between the pipe and sleeve. In the section on pipes passing through fire rated aseembled they are to be caulked "as approved by the local Building Official". Often, this caulk is "Intumescent" meaning it is fire resistant and swells to fill the opening more tightly in the event of heat/fire. These are two different situations. One is to provide room for movement and the other is to prevent fire spread or fumes passing through.
You may not have a sleeve at all. Your pipe traditionally just passed through a hole in the foundation, at least locally that was the case until the code changed a few years ago.
If I were doing what you are trying, I would find some very coarse stainless steel or brass "steel wool" and clean out around the pipe and chink the opening with it. I might also caulk the inside of the opening with excellent silicon based caulk. The steel wool is to prevent the rodent form chewing or digging through and the reason it is brass or stainless steel is to prevent it from rusting away. I would suggest heavy duty scrub pads maybe available at the grocery store or Wally World. The trick is to get it in there tightly enough to discourage the rodent but not so tightly as to prevent some slight movement of the pipe. You could also use brass window screening or hardware cloth available from the Borgs if you can't find the other. Anything both soft and tough and rust resistant.
I suspect the rodents are opportunists. Moving in to avoid cold weather. Make it hard for them and they will go elsewhere. If they have established a family inside the crawl they will be much harder to dissuade.
woodenleg
>Because I live where there was an earthquake 50 years ago, I have to have space for movement in my sewer pipe. My building inspector told me to use slow expandable spray foam. I don't know if it is right or if it will keep the rodents out but I haven't seen any signs of them coming in that way ( other ways, yes ). My cat catches about 3 a day in the fall. I live in a farming area.
Dave
My experience with a recent rat......
Scott in Eastern Iowa
>.......was an all out whatever it takes to win war !!!
I would not go with expandable foam, caulk or any other non hardnening material as it can and will be chewed thru by that rat.
My war started with a single rat, which I believed to be female, that was determined to use my garden shop as her new home. It chewed the vertical sealer strip on the outside of the gargage door (both sides up a good 9", then chewed the dryall and part of the wood framing on both sides of the interior of the door in an attempt to get out, then chewed a small hole in the corner of the garage exterior siding in an attempt to get back in. It even tried to crawl thru a crack in the floor from the outside, but a 1/2" hole was too big for its skull to sqyueeze thru apparently.
Rat traps didnt work, baited live traps didnt work....so I resolved to crushed poison dust in peanut butter and antifreeze to get it. One of the two worked and it hasnt been back, but as you can see this went on for awhile (about 2 weeks) and I was at wits end to get it out.
If I were you Dan, I would use the cement mix or even grouting to take care of the opening. Anything else will not work well imho.
Re: My experience with a recent rat......
Dan Mitchell
>Thanks for the helpful replies. I hadn't thought about the movement thing. I can see that being a potential issue. We're in Seattle, which is somewhat seismic. Still, as Scott says, I can see the damned things chewing through anything much less robust than concrete! That gets to my 2nd concern. The only thing worse than rats in the crawl space is rats in the house! What if we seal them in, with the idea they would then be trapped one by one, but instead of resorting to the baited traps, they work their way into the house! I'm not generally too squeamish, but the idea of rats (not mice mind you, but RATS!) in the house would probably drive me to the local Budgetel. Not to mention how my wife would react!
I have never owned a house with a crawl space before, only a full basement. Although in general I like the house (especially the 3.5 car garage ;-) If I had it to do over again, the existence of a crawl space would be a very serious deterrent to the purchase. Under the previous owner, rats got up in the insulation, a large amount of which has been shredded/brought down/soiled by the rodents. I knew this going in; I was down there with the home inspector & it was in his report. The exterminator also does crawl space clean up, they gave me an estimate of over $7000 to clean up the space, replace the vapor barrier & any needed insulation. I would do this myself if it weren't so awful down there; dark, dirty, plastic bunched up here & there with bare earth elsewhere, about 2 feet of clearance in places, fiberglass everywhere, who knows how many dead rodents. I'm used to doing things myself ("If you want it done right... ") but this is such a nightmare. And why can't the space be LEVEL? OK, not a full basement with 8' ceilings & a poured floor, but at least an even, flat/level dirt floor of 4' clearance. There's a ~5' ditch briefly along one wall, then about 3' in other areas, and basically a mound in the middle with 2' tops! And NATURALLY, the sewer pipe that needs sealing is on the far side where there's low clearance.
Never again...
Dan
Craig in Silverdale
>Perhaps you could use a combination of things. The steel wool should work. Or maybe broken glass stuffed in the space then fill the back side with expandable foam the keep out air leaks and drafts. $7 grand to clean up your crawl space. Email me, I'll bet it can be cleaned up for a lot less than that. I just live across the pond from you.
>Wow! 7G's to clean a crawl space. And you know they are going to hire a couple of people that will do the jobs Americans don't want to do and pay them $10 an hour for a day or two. I'm in the wrong line of work.
Dan, another approach to this is to do it from the outside. If the lines are not too deep, you and dig them up and fill in around them with gravel. Gravel with sharp edges, not river stone. Locally, you can buy it at garden centers. A Product named PermaTill is made for the purpose of stopping rodents from borrowing through the soil and eating the roots of your plants. It would work in this application too.
Sounds like your builder did not level the inside of your crawl. Shame on him for a half A$$ job. Locally, I cannot imagine paying over $1000 or 1500 to fix the insulation and another $150 to 250 to install a proper vapor barrier. An Insulation company will do both.
Dan Mitchell
>Thanks Barry. Yeah, that's one reason I didn't go ahead with it. Just seemed too high. Meant to get other bids, but well, you know how things just don't get done sometimes. There's a company around here called "Clean Crawl" that specializes in this, and as you say, probably most any insulation co. will do it also. At this point, I'm thinking I'll just replace all the insulation (some of the insulation is R-11, some is R-19. The $7,000 bid was for just the R-19, which they are saying amounts to ~1400 sq') if I can get a reasonable price. One company touts a huge, truck mounted vac with a 6" hose they use to vacuum the space. No point though until I get rid of the bloody rats!
Dan
>Dan, check with a local Borg or any one who sells insulation to homeowners. You should be able to get an insulation company to install the insulation for about what you can buy it for. They get it a lot cheaper than you do. In any event, you should be able to get it installed for less than double what it costs you. I just had R-19 blown into an attic and R-19 batts installed under the floor of an 1100 SF house for about a $1000. They did not do any clean up.
