8" Grizzly jointers - 490 vs 586/593
Rob Ring
>Thinking of putting a Grizzly 8" jointer on the Christmas list. Can anybody explain the advantages of the parallelogram bed design (G0490) vs. the dovetail-ways design (G0586 or G0593). Other than an extra inch or so of length, the only differences I can see are the bed design and 2HP vs 3HP. I have to believe that the 2HP motor is more than enough juice, so I don't see a huge need for 3HP. Is the parallelogram bed design that much better to justify the additional cost?
Also, the spiral cutterheads available on each appear equivalent, yet there's a $330 premium on the G0593 vs a $470 premium on the G0490. And it actually appears about $100 cheaper after shipping to buy the G0490 with straight knives and purchase the spiral upgrade separately. Am I missing something?
One last question - a previous post on this topic stated that the spiral cutterheads on the grizzly weren't Boyd. The replacements on the Grizzly website are boyd, but it's unclear about the spiral heads shipped pre-installed. can anybody confirm whether they're Boyd also?
Rob
Re: 8" Grizzly jointers - 490 vs 586/593
Bill White
>Do you mean Bird Cutterheads?
Bill
Re: Simple enough
Brian in Brighton
>I bought the 490 because I asked this same question and most everyone at WC agreed that the parallelogram bed was better. You can do a search as to why.
The replacement spiral head that is a "Shelix" head is indeed from Byrd. I bought it with my jointer and changed it myself in about 2 hours. The stock Grizzly is NOT from Byrd.
I'm very happy with mine.
Brian in Brighton
keithhankins
>Well, the 8" with the spiral cutterhead is out of stock. I know I called today and checked on it and the 12". I wanted the 12 anyway, so it made the decision easier. I've been looking for about 6 months or longer on the purchase I just made so I've done the homework. As someone who had a 6" get the biggest one you can afford, and you won't regret it. The designs between the dovetail .vs. the parallel is that you have complete adjustment capability. You can adjust the left and right side of the infeed and outfeed tables simletaneously. With the dovetail, you can go up and down but if you need the left side higher than the right you have to shim to get it right. Can be done, just a bigger pain. The spiral cutterhead is very nice. Blade changes in a jointer is a pain in the arse! Inserts are a piece of cake to change. I would spring for the 3hp, but you will need a 20 amp 220 circuit to run it. I ordered the G0609 with 4 blade head. I will upgrade to the byrd head next year. Good luck!
Patrick Schupbach
>I cant tell you the difference in bed design, but I do own the GO490. Its a great machine. Wish I had the spiral cuutterhead. Also, this unit was shipped undamaged and adjusted dead-on out of the crate. Hope this helps!
Larry Clinton At Frankfort (Central)., Indiana
>"Thinking of putting a Grizzly 8" jointer on the Christmas list. Can anybody explain the advantages of the parallelogram bed design (G0490) vs. the dovetail-ways design (G0586 or G0593). Other than an extra inch or so of length, the only differences I can see are the bed design and 2HP vs 3HP. I have to believe that the 2HP motor is more than enough juice, so I don't see a huge need for 3HP. Is the parallelogram bed design that much better to justify the additional cost?"
I have the G0-593 (dovetailed ways with wheel adjustment). This machine is equipped with the Grizzly version of the Byrd cutterhead.
The Byrd is supposed to have some advantage due to the inserts being angled in the head and /or a radius. However I also have a 20" Planer with the Byrd cutterhead system and can see no difference in the cut quality - even with very gnarly woods. I have never had any issue with lack of horsepower, never heard the machine slow even with full width cuts on White oak. The parallelogram beds are supposed to be easier to align, but I have never found any reason to need to align my joiners. I used the Grizzly 6" for several years before replacing it with the 8" - sold it to a good friend - the beds were as straight, coplanar and flat as new after about 14 years. (and I lifted it by the beds several times.).
"Also, the spiral cutterheads available on each appear equivalent, yet there's a $330 premium on the G0593 vs a $470 premium on the G0490. And it actually appears about $100 cheaper after shipping to buy the G0490 with straight knives and purchase the spiral upgrade separately. Am I missing something?"
Didn't look into that, however Griz does sell both the actual Byrd head and their version made in China. Don't know if that is the issue or just a special price on the 593.
"One last question - a previous post on this topic stated that the spiral cutterheads on the grizzly weren't Boyd. The replacements on the Grizzly website are boyd, but it's unclear about the spiral heads shipped pre-installed. can anybody confirm whether they're Boyd also?"
As I said, Grizzly sells both the Byrd and their Chinese version of the segmented spiral cutter head (and replacement inserts for both). The G0593 does come with the Grizzly version - per the above info, I can't see any performance difference, although the Grizzly heads and inserts are quite a bit cheaper.
