OT: Hot tub suddenly tripping breaker
Mike Schwing from Md.
>Hi all. Looking to get some thoughts on this before calling in for service. We have a hot tub on the back deck that has been operating properly for more than a year. Yesterday the breaker tripped while I was in the tub with just the number 1 pump running on full. After a breaker reset it appeared to return to normal. The same thing happened to Mrs. Schwing last evening.
The tub is on a 60amp breaker with a "test" feature. The test button correctly shuts the breaker.
Nothing else has changed other than I filled it up a little bit higher than normal, in anticipation of the end of the water supply from the hose due to upcoming freezing temps. The breaker does not trip during the maintenance cycles when the pumps run on low.
Any thoughts? I'm no electrical whiz but a short does not seem likely to me. Perhaps a motor going bad? Anything that I can do to triage the situation?
Thanks.
